Why triplet state |1,0> is considered parallel ?
In summary, the triplet state |1,0> is considered "parallel" because it is one of the three symmetric spin states of 2 spin 1/2 particles. However, it is more accurate to describe it as a "symmetric" spin state and its behavior is dictated by the Pauli principle, which requires the total wave function of identical fermions to be antisymmetric. This means that if two electrons occupy the same orbital, their spin state must be in the singlet state.
harrists
why triplet state |1,0> is considered "parallel"?
let there be a system of two electrons and thus have s1=s2=1/2 and m1=m2=+-1/2.
the singlet state is:
|0,0> = 1/sqrt(2) ( |1/2,-1/2> - |-1/2,1/2> )
and the triplet
|1,1> = |1/2,1/2>
|1,0> = 1/sqrt(2) ( |1/2,-1/2> + |-1/2,1/2> )
|1,-1> = |-1/2,-1/2>
Since they are fermions the total wavefunction has to be antisymmetric.
So, if Stotal = 0 it has to be m1 = -m2 which leads to an antisymmetric spin function so the spatial w/f has to be symmetric.
We consider this spins' state as "antiparallel" and i can totally understand the reason.
(As i also know the spins cannot really be parallel.)
Given that the spins are antiparallel, the two electrons are permitted to occupy the same quantum state. (the rest quantum numbers,except m, to be equal).
Right?
In case Stotal = 1,
i am a bit confused.
All the three triplet states are symmetric, so the spatial w/f should then be antisymmetric.
I have read that, in this case, we consider the spins as parallel, m1 = m2
so the two electrons are not permitted to occupy the same quantum state.
For example, if they both exist in a quantum well, then the one should occupy the basic (n=1) energy state and the other should occupy the next one (n=2).
I wonder why do we consider the state:
as "parallel" spin state and therefore enable pauli's exclusion principle ?
Thank you for your help.
The symmetry of the wave function is not dictated by spin alone; instead of constructing the two-particle state from the single particle state |sz> you have to construct it from |n,sz> where n labels the energy levels of the quantum well or the harmonic oscillator. The total wave function has to be antisymmetric.
So you can e.g. have
[tex]|n,s_z\rangle_1 = |n_1,+>[/tex]
[tex]|n,s_z\rangle_2 = |n_2,+>[/tex]
[tex]|\psi\rangle = \text{anti-symm}\;|n_1,+\rangle \otimes |n_2,+\rangle = \frac{1}{\sqrt{2}}\left( |n_1,+\rangle \otimes |n_2,+\rangle - |n_2,+\rangle \otimes |n_1,+\rangle\right)[/tex]
Now you see that both electrons can have the same spin state '+' but must differ w.r.t. n; with the same n the state would be 0 trivially.
As you can see it's really not right to call this a "parallel" spin state. We should really call it a "symmetric" spin state. Often it is called a "triplet" spin state since it is one of the three symmetric spin states of 2 spin 1/2 particles.
The precise and general statement of the Pauli principle is "the state of a system of a system of multiple identical fermions must be antisymmetric under exchange of any two of the particles." The behavior of electrons in atoms is a specific instance of this general principle. If two electrons occupy the same orbital in some atom, their two-particle spatial wave function is symmetric; the Pauli principle then requires that their spin state be antisymmetric; i.e., they must be in the singlet spin state. This situation gets simplified in less technical contexts as "electrons in the same orbital must have antiparallel spins," but this wording is not really quite correct: really they must be in the singlet spin state.
Related to Why triplet state |1,0> is considered parallel ?
1. Why is the triplet state |1,0> considered parallel?
The triplet state |1,0> is considered parallel because it has two unpaired electrons with the same spin, resulting in a total spin of 1. This configuration is known as parallel because the two unpaired electrons align their spins in parallel with each other.
2. What is the significance of the parallel spin configuration in the triplet state |1,0>?
The parallel spin configuration in the triplet state |1,0> is significant because it makes the state more stable. This is due to the fact that parallel spins experience a stronger exchange interaction, which lowers the overall energy of the system.
3. How does the parallel spin configuration affect the properties of the triplet state |1,0>?
The parallel spin configuration in the triplet state |1,0> affects its properties in several ways. For example, it leads to a longer lifetime of the state, making it more persistent. It also affects the magnetic properties of the state, making it more magnetic than the singlet state |0,0>.
4. Why is the triplet state |1,0> more commonly observed in nature?
The triplet state |1,0> is more commonly observed in nature because it is energetically favored over the singlet state |0,0>. This is due to the fact that the parallel spin configuration in the triplet state results in a lower energy compared to the antiparallel spin configuration in the singlet state.
5. Can the parallel spin configuration be observed in other quantum states besides the triplet state |1,0>?
Yes, the parallel spin configuration can be observed in other quantum states besides the triplet state |1,0>. This configuration can also be found in higher energy states such as the quintet state |2,0>. However, the triplet state is the most commonly observed state with a parallel spin configuration due to its stability and lower energy.
