JavaScript Why use spread operator in this react program? What does it do?
  • Thread starter Thread starter shivajikobardan
    Operator Program
The discussion focuses on the use of the spread operator in JavaScript, particularly within the context of React.js. The user describes a program flow where a button click triggers a function that updates the state from an empty array to an array containing an object. The user seeks clarity on the purpose of the spread operator, noting that while they understand its basic function from MDN documentation, they struggle to apply it in practical scenarios. The spread operator, represented by three dots (...), is explained as a means to create new arrays or objects by combining existing ones without altering the originals. Examples illustrate how it can merge arrays and objects effectively. The spread operator is highlighted as a valuable tool in React for passing props and creating shallow copies. The user acknowledges that their understanding was enhanced by consulting ChatGPT and references relevant documentation for further learning.
shivajikobardan
TL;DR
spread operator in react js.
Code for this is here:
https://codesandbox.io/s/floral-frog-7zfon3
I got the general idea of program flow in this case.
First user clicks a button, then function gets called, that function in turn updates the state from initial [] state to [{id:1,value:0.12232}]. Now the array map accesses the value and displays in a list.
But I don't understand why did we use spread operator there. If I remove spread operator, I can see the difference, but I'm not understanding what spread operator is doing here enough to apply the concept of spread operator in other projects.
I have learnt about spread operator from MDN docs already.
Technology news on Phys.org
The spread operator is actually a part of javascript ES6 not react.js
However, the spread operator in React.js is used to spread an array of values or the properties of an object into a new array or object. It is represented by three dots (...).
Here is an example of how the spread operator can be used in React.js to create a new array that combines two existing arrays:
JavaScript:
const array1 = [1, 2, 3];
const array2 = [4, 5, 6];
const combinedArray = [...array1, ...array2];
// combinedArray is now [1, 2, 3, 4, 5, 6]
The spread operator can also be used to spread the properties of an object into a new object:
JavaScript:
const obj1 = { a: 1, b: 2 };
const obj2 = { c: 3, d: 4 };
const combinedObject = { ...obj1, ...obj2 };
// combinedObject is now { a: 1, b: 2, c: 3, d: 4 }
The spread operator is a useful tool for creating new arrays or objects that are based on existing ones, without modifying the original arrays or objects. It is often used in React.js to pass props from a parent component to a child component or to make a shallow copy of an object or array.
References:
MENTOR Note: I got most of this answer by asking ChatGPT about the spread operator for react.js and asking it to cite references
My citation reference is::
thank you
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 23 ·
