Why vacuum has negative pressure?
In summary, the pressure of the Casimir effect is relative to the rest of the laboratory, and it is impossible to achieve zero pressure. Furthermore, the Casimir effect is a result of the boundary conditions at the plates.
scope
61
hi,
does anyone know why vacuum energy has negative pressure?
is it only experimental or it is theoretical too?
i also wonder if the negative pressure of the Casimir effect is absolutely negative or if it is relatively negative relatively to the rest of the laboratory?
i would be grateful for any reply!
There is nothing like negative pressure.
Furthermore, it is impossible to achieve zero pressure.
and what about the casimir effect?
i mean you said pressure can not be negative, but pressure seems to be negative for the casimir effect, so what is to be believed? is it absolute negative pressure?
Hi,
I think if you take the magnitude of the force, then the calculated pressure is negative. If you take the value of force together with its sign (which is negative), then pressure is positive.
But i am not not 100% sure about Casimir effect. So maybe some expert will advice you.
cheers
Thinking of the Casimir effect in terms of pressure, you can posit that the virtual particle-antiparticle pairs of the quantum vacuum have an effect on macroscopic objects. If you put two flat parallel plates of a Casimir device (other shapes have been used) very close to one another, you can suppress the emergence of virtual pairs of any wavelength larger than that separation. The Casimir effect (attraction of the plates) can be thought of as the reduction of "pressure" between the plates. There other interpretations, but you should be able to dig those up if you are interested. Casimir wanted to calculate the magnitude of the Van der Waals force between molecules of the materials comprising the plates. I don't know if he had any other motivation - you should be able to dig into that though.
There is an interesting macroscopic parallel in the behavior of ships. If you position a ship closely enough to another to suppress larger waves in the space between them, the wave action of the water on their out-sides will tend to force them together.
How strong is this effect?
You can look it up. It is significant.
scope said:
[...] but pressure seems to be negative for the casimir effect, so what is to be believed? is it absolute negative pressure?
Don't "believe" anything -- work through the math... :-)
The vacuum state is just the lowest-energy state for a particular Hamiltonian
and boundary conditions. It's misleading to think that the "vacuum" of infinite
spatial extent is somehow the same as the "vacuum" between two parallel
conducting plates. In QED those cases are significantly different.
With the Casimir effect, the boundary conditions at the plates mean there's
fewer possible EM modes when the plates are closer together, hence less energy.
That manifests as a force pushing the plates together since the system will try to
move towards a lower energy state.
turbo-1 said:
You can look it up.
Do you recommend any particular place to attempt so? The most I found so far was the wikipedia "Casimir effect" talk page, debating whether or not the effect between ships is a myth.
As we know that vacuum is a place having nothing,therefore, the negative presssure may be due to the Newton third law !
Related to Why vacuum has negative pressure?
1. Why do we perceive vacuum as having negative pressure?
The concept of negative pressure in a vacuum is related to the absence of matter or particles. In a vacuum, there is no air or any other gas molecules to create pressure, so the pressure is considered to be negative.
2. How does negative pressure in a vacuum affect objects?
Negative pressure in a vacuum can have a significant impact on objects. It can cause objects to expand or contract, depending on their material properties. Objects may also experience a force towards the vacuum due to the difference in pressure.
3. Is there really no pressure in a vacuum?
While we often refer to the pressure in a vacuum as being zero or negative, there is still a very small amount of pressure present. This is known as the vacuum pressure or the residual pressure and is caused by the tiny amount of gas molecules that still exist in the vacuum.
4. What is the significance of negative pressure in a vacuum?
Negative pressure in a vacuum has significant implications in many scientific fields. It is crucial in understanding the behavior of gases, the movement of particles, and the functioning of various devices such as vacuum pumps and vacuum chambers.
5. Can negative pressure in a vacuum cause harm to living organisms?
Negative pressure in a vacuum can be dangerous for living organisms as it can cause the gases inside their bodies to expand, leading to tissue damage or even death. However, in a controlled environment, such as a vacuum chamber used in scientific experiments, it is not harmful as long as proper precautions are taken.
  • Quantum Physics
  • Classical Physics
  • Quantum Physics
  • Classical Physics
  • General Engineering
