Why wasn't the Big Bang an isotropic explosion?
In summary, the Big Bang was not an "explosion" in space, and space itself expanded (and continues to expand). The equilibrium of an isotropic distribution of matter is unstable, and the universe underwent inflation to achieve a flat and isotropic state.
randybryan
52
I'm sure I'm making a plethora of naive assumptions in this question, but I was just thinking that the Big Bang, or the birth of our universe should logically be isotropic if space and time is assumed to be homogenous and infinite in every direction.
Space news on Phys.org
Isotropic up to quantum fluctuations. Yes, that is the usual assumption (and observations agree very well with that). Note that the big bang was not an "explosion" in space. Space itself expanded (and continues to expand).
Space does not have to be infinite, but it is probably without a boundary. This is not a contradiction, see the surface of Earth for example: finite area, but no boundary.
Thanks for the reply. I did actually think explosion was a poor lexical choice, so thanks for correcting me. How were stars and galaxies formed then if the expansion is isotropic? Is this explained by quantum fluctuation alone?, there should surely be a homogenous gravitational field, which would mean matter shouldn't cluster? My knowledge of cosmology, as you can probably tell, is very limited.
Gravitational equilibrium of an isotropic distribution of matter is unstable; Newton understood this and so proposed an infinite distribution of stars.
This the slightest imbalance, anywhere, or at anytime will start the gravitational agglomeration of matter.
But such a slight imbalance at any time during the Big Bang, early or late, will result in inhomogeneity at some level - this is where detailed models must be compared to observational evidence in order to refine our understanding.
Likes 1 person
How come gravitational equilibrium of an isotropic distribution is unstable? Is there a good book you would recommend reading? I don't know if I'm verging on some seriously difficult physics here...
"Philosophiæ Naturalis Principia Mathematica" by Isaac Newton - if you read Latin!
http://en.wikipedia.org/wiki/Philosophiæ_Naturalis_Principia_Mathematica
But the argument is simple:
One object alone exerts gravity on nothing but itself.
Two objects exert gravity on each other, and are attracted. If they were originally still they will collide; if they had their own motions they will follow a conic section: parabolic (a bullet), hyperbolic (some comets), elliptical (planets)
What if you arrange 3 in a line? Then maybe you can cancel the net gravity on the middle one, but the other two are still going to move.
Keep adding one more, and every arrangement is unstable.
In the limit you can generate an infinite array - like a giant salt crystal, but with stars instead of atoms of Cl and Na - with an equal number of stationary attractors in each direction.
But once the perfect alignment is broken, you will have worlds in collision!
The basic idea is quantum fluctuations resulted in slightly overdense regions in the early universe. These over dense regions show up as temperature fluctuations in the CMB. So, thanks to quantum fluctuations, the universe was never truly homogenous.
Awesome. Thanks for the reply. Definitely going to read up on some cosmology
sooo if you get to the edge of the universe you go to the beginning?
There is no "edge of the universe".
I thought space-time was finite:confused:
The surface area of a sphere is finite ... but there is no edge.
In what sense?
There are models of the universe for which space finite, but I know of no seriously considered models of the universe for which spacetime is finite. In fact, all spacetimes that satisfy a certain finiteness condition have closed timelike curves.
It's the other way around: isotropy implies homogeneity (the easy example is a homogeneous electric field pointing in a given direction: it's uniform but not isotropic). While we happen to observe that isotropy holds on relatively large scales today, we can't easily extrapolate that back to the early universe, for reasons of instability mentioned above. To get around these, one must fine tune the initial curvature of the universe to an immense degree. The idea that the very early universe emerging from the big bang was flat and isotropic is therefore by no means a natural proposal. Inflation, a period of accelerated expansion in the very early universe, can be invoked to dynamically push the universe to flatness and isotropy.
Related to Why wasn't the Big Bang an isotropic explosion?
1. Why wasn't the Big Bang an isotropic explosion?
The Big Bang was not an isotropic explosion because the explosion did not happen in a single point in space. Instead, it occurred everywhere in the universe at the same time, resulting in the expansion of the universe in all directions.
2. What evidence supports the idea that the Big Bang was not an isotropic explosion?
One of the main pieces of evidence for the Big Bang theory is the cosmic microwave background radiation. This radiation is isotropic, meaning it is evenly distributed in all directions, which is consistent with the idea that the universe expanded in all directions from a single point.
3. How does the concept of inflation explain the lack of isotropy in the Big Bang?
Inflation is a period of rapid expansion that occurred in the early universe. This expansion was not uniform, causing small density variations to be stretched out across the entire universe. This is why we see small differences in the cosmic microwave background radiation, providing evidence against an isotropic explosion.
4. Could the Big Bang have been an isotropic explosion if the universe was smaller?
No, the size of the universe does not affect the isotropy of the Big Bang. The expansion of the universe in all directions is a fundamental aspect of the Big Bang theory and would have occurred regardless of the initial size of the universe.
5. Are there any current theories that suggest the Big Bang was an isotropic explosion?
No, there are currently no theories that suggest the Big Bang was an isotropic explosion. The evidence from the cosmic microwave background radiation and the concept of inflation strongly support the idea that the Big Bang was an expansion of the universe in all directions from a single point. However, scientists are continuously studying and exploring new ideas and theories about the origins of the universe.
