Why when two conductors connected by a conducting wire gain the same potential?
In summary: trying to say is that the potential difference (voltage) between the two spheres will stay the same no matter how much current is flowing through the wire connecting them.
nishantve1
76
Why when two charged conductors connected by a conducting wire gain the same potential .
Lets say we have two spheres of different charges why when we connect them by a single copper wire they gain the same potential
Thanks in advance
hi nishantve1! :wink:
tell us what you think, and then we'll comment! :smile:
I am new to Electrostatics , first of all I have no idea but still what I am able to figure out is maybe the charges on both become equal but I see that's not much to do with the potential or is it am I right ?
nishantve1 said:
I am new to Electrostatics …
ok, well, always start with the definitions, then write out all the equations you know, and see if any of them help …
(btw, that is why the pf homework template requires you to write out the equations first, and please post in the homework sub-forum in future)
DEFINITION:
what is electric potential?
what does it do?​
EQUATIONS:
what equations do you know for electric potential?​
Sorry , next time I will definitely post in homework sub forum
Electric potential I know is Work done per charge in bringing it from infinity to a point .
Electric potential is Like gravitational potential it The closer a test charge is to a electric field source more potential energy it has and thus more Electric potential .
Electrons flow from higher to lower potential that's what makes electricity flow V(a) - V(b) = integral from a to b E.dl
E = -dV/dr
V = E.d
Due to a point charge at a distance R the electric potential is Q/4 pi Epsilno0 R
mmm … that's only if the potential defined to be zero at infinity (in electric circuits, it usually isn't :wink:)
better is to talk about potential difference
electric potential difference
= potential energy difference per charge
= minus work done, per charge, by the electric field :wink:
Electrons flow from higher to lower potential …
i always get confused about this :redface:, but isn't that for positive charge? :confused:
ok :smile:, now call the potentials V and W, and apply the above to how an individual charge will move, and how that will affect the potential difference
oh yeah electrons flow form lower to higher potential .if both the bodies have charge of same polarity say Positive then electrons from one with lower potential say W will flow to one with higher potential V . now what ? the electrons will go and neutralize the positive charge on the other one . And if there polarities were to be different then electrons will flow the same way as above . I am seriously not able to figure out please Help me !
you're more or less there :smile:
the information you haven't yet used is that there's only a fixed amount of total charge
(i assume the spheres are isolated, ie not connected to any voltage source)
so if the total charge is fixed, what's going to happen? :wink:
Ok so let's name the spheres there is Sphere A with four Positive charges (just keeping things simple) and is at a higher Potential and the another sphere B has one Positive charge and is at a lower potential .
{That means the work done per charge on Bringing a test charge from a Point where we assume U to be 0 will be higher in case of A } Now we connect them by a conducting wire , so the electrons from A will want to flow to B . and since the charge is conserved we have only 5 positive charges in the system .
Now what the charges on A and B could be like
5 0
6 -1
7 -2
8 -3
and similarly many keeping the charge +5 constant What happens then
Hi. Say two charged conductors of charge +Q, -Q form condenser of electrostatic capacity C. So, potential difference is V=Q/C.
WHY: By current in connecting wire Q decrease so V also decrease.
WHEN: When Q=0, V=0 same potential.
Regards.
I have also learned that if there are two bodies(with similar characteristics) with charges Q1 and Q2 if they are brought in contact the charges gets distributed like (Q1 + Q2)/2 . Is that the case here
Regards.
I get what you are trying to say . but how does charge Q becomes 0 ?
5 0
6 -1
7 -2
8 -3
nishantve1 said:
… if there are two bodies(with similar characteristics) with charges Q1 and Q2 if they are brought in contact the charges gets distributed like (Q1 + Q2)/2 . Is that the case here
that's right! :smile:
so it'll go (it's easier with an even number :wink:)
6 0
5 1
4 2
3 3​
sooo … when the charges are equal, what is the potential difference (and why?)
tiny-tim said:
6 0
5 1
4 2
3 3 [/INDENT]
When the charges are equal this means that they are at the same potential . So the potential Difference will be zero . Its very easy to understand that Equal charges are at the same potential . Is it like the Potential Energy required in bringing that charge from infinity to a point in space is same for the other charge since they are equal in magnitude . Is there any Mathematical Equation that proves it I mean I tried using
V(a) - V(b) = Integral from A to B E.dr
which should be zero but how ?
ooops! :redface:
i thought these were identical spheres, but looking back, they're not
so … correction … the charges won't equalise, although the potentials will equalise
so the question should be, why will the electrons keep moving while the potential difference is non-zero, and stop moving when the potential difference is zero? :wink:
Hi.
You say Why Ohm's law V=RI.
Regards.
Hi.
Cancel of Q in positive charge plate and -Q in negative charge plate. Total discharge of battery.
Regards.
I am still in Capacitance so No idea about Ohm's law . Also its almost time I have to go to school . If someone please please explain it I will be very thankful . Also if potential difference is zero why will electrons move ? If I am still not Familiar with current Electricity is this question out of the scope ?
@sweet springs I got that but what if both charges were of same polarity and different magnitude ?
Related to Why when two conductors connected by a conducting wire gain the same potential?
1. Why do two conductors connected by a conducting wire gain the same potential?
The potential of a conductor is determined by the amount of charge it holds. When two conductors are connected by a conducting wire, the charges on the conductors will redistribute until they reach equilibrium. This causes both conductors to have the same potential.
2. Does the length of the conducting wire affect the potential of the connected conductors?
No, the length of the conducting wire does not affect the potential of the connected conductors. As long as the wire has low resistance, the potential will remain the same throughout the wire.
3. How does the potential of a conductor change when connected to a battery?
When a conductor is connected to a battery, the battery provides a constant potential difference between its terminals. This causes the charges on the conductor to redistribute until it reaches the same potential as the battery, resulting in a change in the potential of the conductor.
4. Can two conductors with different potentials be connected by a conducting wire?
Yes, two conductors with different potentials can be connected by a conducting wire. However, the potential will equalize between the two conductors until they both reach the same potential.
5. How does the potential of a conductor change when connected to a power source?
When a conductor is connected to a power source, the potential of the conductor will change depending on the type of power source. For example, a battery will provide a constant potential difference, while an alternating current power source will cause the potential to fluctuate over time.
  • Electromagnetism
  • Electromagnetism
