Why wire experiences force in magnetic field, when net charge is zero.
In summary: Lorentz Force is a force that arises due to the electron's motion. It's what causes the force that holds a wire in a magnetic field.
ZedCar
354
In a current-carrying wire, the total net charge in the metal is zero. Why does the wire experience a force when placed in a magnetic field?
The reason for the force is the motion of the electrons, not their charge as such.
i.e. it's a relativistic effect due to their motion.
The current traveling in the wire creates its own magnetic field which interacts with the external one. Depending on the relative angles of the fields, there will be a resulting force acting on the wire.
uhh? do magnetic fields interact? :confused:
use the force! :biggrin:
Do you mean, just go with the first part?
i.e. The reason for the force is the motion of the electrons, not their charge. It's a relativistic effect due to their motion.
no, i mean the lorentz force! :smile:
(is there any other? o:))
A common misconception people have is that if the net charge is zero, then that implies the net current density is also zero. But if you think about it for a moment, you'll see that this is not true; you can have electrons rushing by static protons at some net drift speed and still have the total number of electrons and protons in any unit of volume in the wire be equal to zero.
Is this the issue here, or are you asking why it is that a net current couples to a magnetic field in the same way that an electric field couples to a net charge?
Do you mean none of my original answer in the first post is particularly good and the reason is simply due to the Lorentz Force?
erm … yes :redface:
Okay
FAQ: Why wire experiences force in magnetic field, when net charge is zero.
What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be observed. It is created by moving electric charges, such as those found in magnets or electrical currents.
Why does a wire experience force in a magnetic field?
A wire experiences force in a magnetic field because the moving electric charges within the wire interact with the magnetic field, resulting in a force being exerted on the wire. This force is known as the Lorentz force.
Why does the net charge of a wire affect its force in a magnetic field?
The net charge of a wire does not affect its force in a magnetic field because the force is dependent on the movement of charges, not their overall charge. Even if the net charge of a wire is zero, the individual charges within the wire can still experience a force in a magnetic field.
How does the direction of the magnetic field affect the force on a wire?
The direction of the magnetic field determines the direction of the force on a wire. The force will be perpendicular to both the direction of the magnetic field and the direction of the current in the wire.
What are some real-world applications of the force on a wire in a magnetic field?
The force on a wire in a magnetic field is utilized in many devices, such as electric motors, generators, and transformers. It is also used in particle accelerators and magnetic levitation systems.
