LarryJ
- 5
Two objects, of masses m1 = 485.0 g and m2 = 494.7 g, are connected by a string of negligible mass that passes over a pulley with frictionless bearings. The pulley is a uniform 53.0-g disk with a radius of 4.08 cm. The string does not slip on the pulley.
Find the accelerations of the objects.
Find the tensions of each area of the string between the masses and the pully.
T2R-T1R = I x (angular acceleration)
Tension is found by mass x gravity
If I can solve for the angular acceleration by knowing the inertia, then I should be able to find the acceleration of the masses by multiplying the angular acceleration by the radius. But I keep getting the wrong answer. What am I doing wrong?
