sevensages
- 71
- 14
- TL;DR Summary
- Why would disconnecting the positive cable on a car battery before disconnecting the ground cable on a car battery cause damage to the battery and sparks to fly?
When I was 18 years old, I worked at an automobile repair shop doing oil changes and other light mechanical work. The automobile repair shop hired me for this work to free up their real auto mechanics to do more advanced automobile repair work. One time I was assigned the task of replacing a defective car battery with a new car battery. I got a wrench, and I started loosening the bolt holding the positive cable on the defective car battery. I was going to first remove the positive cable on the car battery, and then I planned on removing the ground cable after I removed the positive cable. The mechanic supervising me stopped me before I could remove the positive cable. The mechanic said that if I removed the positive cable first, sparks would have flew everywhere, and all sorts of disastrous results would have ensued. I'm not 100% sure, but I believe the mechanic also said that if I removed the positive cable first, it would have damaged the car battery and maybe other equipment on the car.
Why would disconnecting the positive cable on a car battery before disconnecting the ground cable on the car battery cause damage to the battery and sparks to fly?
I suppose that if one disconnects the positive cable on a car battery first, there would be an electrical circuit between the car battery and through the car from the battery to wherever on the car's frame that the other end of the ground cable connects to. I don't definitely know that there would be an electrical circuit between the car battery and through the car from the battery to wherever on the car's frame that the other end of the ground cable connects to. It is just my supposition. Why is that my supposition? Otherwise, why would sparks fly without an electrical circuit?
Am I correct that if one disconnects the positive cable on a car battery first, there would be an electrical circuit between the car battery and through the car from the battery to wherever on the car's frame that the other end of the ground cable connects to? If so, why wouldn't that circuit exist BEFORE the positive cable was removed?
If there is an electrical circuit if one disconnects the positive cable on a car battery first, why does the existence of that electrical circuit cause sparks to fly? How would that electrical circuit damage the battery of the car?
