Why would the car move forward after being hit
  • Thread starter o0griff0o
  • Tags
    Car
In summary, vehicle 1 traveled 5 ft further than vehicle 2 before coming to rest due to a lower coefficient of friction on the grass compared to the road. This caused vehicle 1 to continue moving while vehicle 2 came to a stop.
o0griff0o
Explain why vehicle 1 traveled 5 ft further than vehicle 2 before coming to rest. Would you have expected it to come to rest at the same time as vehicle 2? Why or why not?
Mass of vehicle 1 = 1406.13 kg
mass of vehicle 2= 1950.45 kg
Newtons third law
I figured out that once they collide they become stuck for a few seconds and then separate with the first car traveling 5 ft further. The accerelation I found out was -7.84m/s^2.
I was thinking maybe the car travels further due to Newtons third law of equal and opposite forces.
How when a object of larger mass hits a object of smaller mass the larger mass still moves forward alittle bit b4 it stops and the force of the larger mass gets transferred to the smaller cart.
Am I on the right track? I don't know how to explain it further...
here is the diagram of the car accident
http://i601.photobucket.com/albums/tt92/…
Or Maybe does inertia of after the two cars seperating make sense?
Can we get a description of the car accident? I think you gave the wrong link.
http://i601.photobucket.com/albums/tt92/o0griff0o/crashcar.png
Hopefully this works
The scenerio is somone is driving east from west towards an intersection. Another person is driving from from North 20 degrees west towards the intesection. And they both collide.
I think you might need to calculate the angles then add up the vectors. The answer should lie within the vectors.
If that's what you mean?
But I'm not exactly sure ; )
Newtons third law
Hint -- what stops the cars? Why should what stops the cars be equal in force (or why may it not be the same)?
Well I'm the friction is what stops the cars but I don't see how friction makes the other car go another 5 feet...
Yep, very good. Friction is what makes the cars stop. What could vary to make the two cars experience different friction coefficients with the road and whatever else they slid across? Also, were all 8 wheels locked during the whole event...?
I get it, so at the point where vehicle 2 stops, that is when vehicle 1 is on the grass. Since the coefficient of friction of the grass is much lower, that is why he stops 5 feet after =D
That would be a good guess!
FAQ: Why would the car move forward after being hit
Why does the car move forward after being hit?
There are several factors that contribute to the car moving forward after being hit. One of the main reasons is the principle of inertia, which states that an object in motion will stay in motion unless acted upon by an external force. In this case, the car's forward motion is not immediately stopped by the impact, causing it to continue moving forward until another force, such as friction or the brakes, slows it down.
How does the car's weight affect its movement after being hit?
The car's weight plays a significant role in its movement after being hit. A heavier car will have more inertia, making it harder to stop or change its direction. This means that a heavier car will likely move further forward after an impact compared to a lighter car.
Can the car's speed affect its movement after being hit?
Yes, the car's speed can have an impact on its movement after being hit. The greater the car's speed, the more difficult it will be to slow down or stop its forward motion after an impact. This is because the car has more kinetic energy, which is the energy of motion.
Are there any other forces at play that cause the car to move forward after being hit?
Aside from inertia, there are other forces that contribute to the car's movement after being hit. One of these forces is momentum, which is the product of an object's mass and velocity. The car's momentum will cause it to continue moving forward after the impact, even if the initial force is no longer present.
Is there any way to prevent a car from moving forward after being hit?
In most cases, it is difficult to prevent a car from moving forward after being hit. However, advanced safety features such as crumple zones and airbags can help absorb some of the impact and slow down the car's forward movement. Additionally, using the brakes immediately after an impact can also help to stop the car's movement.
