- #36
- 27,396
- 18,866
Chris Miller said:True from your frame of reference.
In your own frame of reference you are always at rest, proper acceleration or not. So, reaching ##c## in your own reference frame is an even more forlorn hope!
I think what is being so elusive is the concept of a "finite" infinity. I think if you learn about infinities it'll be clear that there is ZERO possibility to accelerate to c, you go for ever and never reach it...given your persistence, I have concern that you would use up all the "workable" energy in the universe trying to succeed :DChris Miller said:True from your frame of reference.
Chris Miller said:Thanks so much nitsuj. Though maybe it should worry you that this is exactly what I've been trying and mostly failing to say. I guess it's not (yet) possible to say what happens in that (i.e., my) final second, any more than what happened "before" the big bang.
nitsuj said:From your perspective you can continuously accelerate towards c. There will be no fancy or weird physics happening when accelerating 1g at 1,000km/s, 200,000km/s or even 299,785km/s...you will merrily be on your way to approaching c (just as you are now in some FOR)...but for us watching we see that comparatively your proper time is ticking more and more slowly and your meter ruler is contracting as you approach c.Converging to a point where time and length will be null at the exact point you reach c...we observers say you'll never reach c...you say just gimme more time and space I'm making progress.
Huh? time and length do comparatively reduce to null at c, to your point of gamma. I specifically said distant observers would clearly see he won't reach c, but that his perspective he will always make progress...as easily as he can accelerate right now. I guess my point was its no different than the physics he experiences right now...that c is postulated to be invariant and that motion is relative.Mister T said:But what he said is just as wrong as what you've been saying! Here is the corrected version of the portion of the @nitsuj post that you quoted:
You indeed can continue to make progress. You cannot reach a speed of ##c## according to that observer or indeed according to any observer. What you are increasing is the Lorentz factor ##\gamma##. That will continue to increase as you continue to apply the force with your rocket engines. There is no limit on how large you can make ##\gamma##. This is a fact of life for all of the scientists, engineers, and technicians who accelerate particles for a living.
Let ##\epsilon## be a small positive number equal to the difference between your speed relative to Earth and the speed ##c##. There is no limit on how small you can make ##\epsilon##, but it will always be nonzero.
Cool thanks for the explanation phinds! I better understand what an FOR is.phinds said:I disagree. The reason it is nonsensical it NOT because he didn't mention in which of the two frames a measurement was made, it is nonsensical because it describes an activity (measuring the distance between two frames) that just flat does not make any sense. For example, Let's say that you have a frame of reference that is taken as being measured with an origin at a particular point on the moon, with X, Y, and Z axes defined in some understandable way and you have have another FOR that is defined as being at a particular point on the Earth, again with well defined X, Y, and Z axes. Now you could measure the distance between those points of origin but that would not in any real or helpful sense be the "distance between the two FORs" because in nether case is the FOR its point of origin. The FOR encompasses all of space. The FOR on the moon includes the origin of the Earth FOR (and all the rest of space) and the FOR on the Earth encompasses the origin of the moon's FOR. There IS no "distance" between the two FORs, they are just different ways of measuring points throughout space.
Converging for who, how? For you, in you rocket, rulers and clocks seem perfectly normal even if you've been accelerating for a billion years. For earth, you are still moving less than c, and every event in your history can eventually be seen. Neither one ever gets closer to experiencing no time or distance.nitsuj said:Huh? time and length do comparatively reduce to null at c, to your point of gamma. I specifically said distant observers would clearly see he won't reach c, but that his perspective he will always make progress...as easily as he can accelerate right now. I guess my point was its no different than the physics he experiences right now...that c is postulated to be invariant and that motion is relative.
Chris Miller what I said is right, but ah to satisfy the issue grammatically "Converging to a point where time and length are null at c."
Me the at rest guy making measurements of OP's rocket..seeing that as he speeds up his length measurements contract and time measurements dilate compared to my tools...I plot it and see his rulers and clocks won't..."exist at c" or however you preffer it to be said. I'm a strong believer in the invariance of c so would conclude he won't reach it. lolPAllen said:Converging for who, how? For you, in you rocket, rulers and clocks seem perfectly normal even if you've been accelerating for a billion years. For earth, you are still moving less than c, and every event in your history can eventually be seen. Neither one ever gets closer to experiencing no time or distance.
Of interest is that the speed of Earth per the rocket, using the most common convention for a noninertial frame, approaches zero, not c, with unbounded red shift being ever more due to pseudo gravitational shift.
Mister T said:No, time and length do not decrease to zero at speed ##c##. Time dilates and lengths approach zero as the speed approaches ##c##. The difference is more than grammatical. One statement describes a physically-possible process that's occurring every minute of every day at hundreds of facilities across the world. The other describes a physically-impossible event that has never occurred and never can occur.
##\gamma## is defined only for speeds that are less than ##c##. ##\gamma## is not defined for a speed of ##c##. ##\gamma## is a function speed, and the speed ##c## is not in the domain of that function.
nitsuj said:I said Converging to where time and length are null at c...
yea, that was mostly describe as "you can keep accelerating, but will never reach" many many times in this thread. that point was made a ton of times...unless you mean nothing can accelerate towards c...which doesn't make sense...things can accelerate towards cMister T said:There is no such condition to converge to.
