Wick contraction and derivatives
Your Name]In summary, to determine the Feynman rule for a cubic QCD-like interaction term involving a derivative, we must consider momentum conservation at each vertex. The derivative will contribute a momentum factor at the vertex where it is attached, and the remaining fields will be contracted among themselves. The momentum conservation can help determine which field the momentum belongs to.
earth2
86
Hey guys,
one quick question about Wick contractions and derivatives:
Suppose I want to write down all (non-vacuum) Wick contractions of two fields a, and one field A into a cubic QCD-like interaction term of the form
[itex]\partial^\nu A^{\mu, a}(p_1) a_\mu^b(p_2) a_\nu^c(p_3) f^{abc}[/itex]
to get the corresponding Feynman rule (where each field carries also a color index).
How do I cope with the derivative? Normally I'd do a Fourier transform, but how do I know to which field the momentum belongs to? In other words if I Fourier trafo the derivative will it become a [itex]p_1[/itex], [itex]p_2[/itex], or [itex]p_3[/itex]?
Cheers,
earth2
sky
Hello earth2sky,
Thank you for your question about Wick contractions and derivatives. In order to determine the Feynman rule for this interaction term, we need to consider the momentum conservation at each vertex. In this case, the derivative term \partial^\nu A^{\mu, a}(p_1) will contribute a momentum factor p_1^\nu at the vertex where it is attached. This means that the momentum conservation at this vertex will be p_1 + p_2 + p_3 = 0.
In terms of Wick contractions, this means that the derivative will be contracted with one of the fields, and the remaining two fields will be contracted among themselves. This gives us a total of three possible Wick contractions, each corresponding to a different field being contracted with the derivative.
To determine which field the momentum p_1 belongs to, we can use the momentum conservation at each vertex. For example, if p_1 is contracted with A^{\mu, a}(p_1), then the momentum conservation at that vertex would be p_1 + p_2 = p_1 + p_2 + p_3 = 0. This means that p_1 must belong to the field A^{\mu, a}(p_1).
I hope this helps clarify how to determine the Feynman rule for this interaction term. If you have any further questions, please don't hesitate to ask.
Related to Wick contraction and derivatives
1. What is Wick contraction in quantum field theory?
Wick contraction is a mathematical technique used in quantum field theory to simplify the calculation of certain integrals involving field operators. It involves pairing up creation and annihilation operators in a specific way to eliminate some terms and make the calculation more manageable.
2. What is the significance of Wick contraction in quantum field theory?
Wick contraction is significant because it allows for the calculation of important quantities in quantum field theory, such as correlation functions and scattering amplitudes, which would be extremely difficult or impossible to calculate without this technique.
3. How is Wick contraction related to Feynman diagrams?
Wick contraction is closely related to Feynman diagrams, which are graphical representations of particle interactions in quantum field theory. Wick contractions are used to simplify the algebraic expressions that arise in the calculation of Feynman diagrams.
4. What is the role of derivatives in Wick contraction?
Derivatives play a crucial role in Wick contraction, as they determine the type of contraction that occurs between two operators. For example, the contraction between two scalar fields involves taking the derivative of one field and setting it equal to the other field, while the contraction between two vector fields involves taking the derivative of one field and setting it equal to the derivative of the other field.
5. How does Wick contraction account for interactions between particles?
Wick contraction takes into account the interactions between particles by pairing up creation and annihilation operators in a specific way, which leads to the creation or annihilation of particles. This allows for the calculation of scattering amplitudes and other important quantities in quantum field theory that involve interactions between particles.
