binbagsss
- 1,265
- 11
1. Homework Statement
Attached:
I've just changed the notation a tad to make things quicker for me :
##\phi_1=\phi_1(x_1)## and ##\Phi_2=\phi_2(x_2)##
: denotes normal product. i.e annhilator operators are on the RHS, so acting on a vacuum state will give zero.
I can split a field ##\phi_1 = \phi_1^a + \phi_1^c ## , where a denotes the annihilating component of the field and c the creation operator component of the field.
##[\phi(x),\Phi(y)]=0## , different fields commute, important here.
[/B]
I expect the result ## T( \phi_1 \Phi_2 \phi_3 \Phi_4 ) = : \phi_1 \Phi_2 \phi_3 \Phi_4 : + [\phi_1^a,\phi_3^{c}] [\Phi_2^a,\Phi_4^{c}] ##
The last term being fully contracted, as if any field is not involved in a contraction it will be zero when hitting a vacuum state.
If I assume that ##x_1^0 > x_2^0>x_3^0>x_4^0## then:
##T( \phi_1 \Phi_2 \phi_3 \Phi_4 ) = (\phi_1^a+\phi_1^c)(\Phi_2^a+\Phi_1^2)(\phi_3^a+\phi_3^c)(\Phi_4^a+\Phi_4^c)
= (\phi_1^a\Phi_2^a+\phi_1^a\Phi_2^c +\phi_1^c\Phi_2^a +\phi_1^c\Phi_2^c) ((\phi_3^a+\phi_3^c)(\Phi_4^a+\Phi_4^c))=
(\phi_1^a\Phi_2^a+\phi_1^a\Phi_2^c +\phi_1^c\Phi_2^a +\phi_1^c\Phi_2^c) (\phi_3^a\Phi_4^a+\phi_3^a\Phi_4^c +\phi_3^c\Phi_4^a +\phi_3^c\Phi_4^c) ##
Now I will simplify this first expression by noting that anything in the first brackets with creation component on the left hand side will result in a normal ordered term as will anything in the second bracket with a annihilation component on the right hand side, so the only terms I need to consider are:
##= ( \phi_1^a\Phi_2^a +\phi_1^a\Phi_2^c ) (\phi_3^a\Phi_4^c +\phi_3^c\Phi_4^c) = \phi_1^a\Phi_2^a \phi_3^c\Phi_4^c + \phi_1^a\Phi_2^c \phi_3^a\Phi_4^c + \phi_1^a\Phi_2^a \phi_3^a\Phi_4^c + \phi_1^a\Phi_2^c\phi_3^c\Phi_4^c ##
Where here I expect since different fields commute I expect the only term that will not be normal ordered or zero to be coming from the ## \phi_1^a\Phi_2^a \phi_3^c\Phi_4^c ## after two iterations, since commutator of different fields is zero.
## = : : + \phi_1^a\Phi_2^c [\phi_3^a,\Phi_4^c ] + \phi_1^a\Phi_2^a [\phi_3^a,\Phi_4^c] + [\phi_1^a,\Phi_2^c]\phi_3^c\Phi_4^c + ##
## = : : +0+0+0 + \phi_1^a \phi_3^c\Phi_2^a\Phi_4^c+ \phi_1^a[\Phi_2^a, \phi_3^c] \Phi_4^c ##
##= = : : +0+0+0 + : : \phi_1^a \phi_3^c [\Phi_2^a,\Phi_4^c] + \phi_1^a[\Phi_2^a, \phi_3^c] \Phi_4^c ##
QUESTION
So I have one commutator that is non-zero ## [\Phi_2^a,\Phi_4^c] ##, however there is no fully contracted term since ##\phi_1^a , \phi_3^c ## are not contracted. Where has my proof gone wrong to not reveal a fully contracted term?
Many thanks in advance !
