Width of a rectangular frame in terms of x.
In summary, by bending a 16 cm wire, a rectangular frame with perimeter 16 cm is made with length x and width 8-x. The area of the frame is 11 cm^2, which can be represented by the equation x^2-8x+11=0. By solving this equation using the quadratic formula, x can be found to be 1.76 or 6.76.
mathlearn
331
By bending a 16 cm wire a rectangular frame is made.
By taking the length as x , write the width in terms of x.
If the area of the frame is $11 cm^2$ show that x satisfies the equation $x^2-8x+11=0$
Solve the equation by taking the $\sqrt{5}=2.24$
Ideas on how to begin ? (Happy)
Mathematics news on Phys.org
Well, the perimeter (P) is 16 centimetres, and P = 2L + 2W, where L is length and W is width. Can you work with that?
16=2x+2width
16-2x=2 width
8-x= width
Correct ? :)
Now area =$11 cm^2$
x*$\left(8-x\right)$=11
$-x^2+8x=11$
$-x^2+8x-11=0$
Correct ? :)
Yes! :)
Now using the quadratic formula, on $-x^2+8x-11=0$$x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$.
$x=\frac{-8\pm\sqrt{64-44}}{-2}$.
$x=\frac{-8\pm\sqrt{20}}{-2}$.
$x=\frac{-8\pm\sqrt{4}\sqrt{5}}{-2}$.
$x={+4\pm-1*\sqrt{5}}$.
$x={+4\pm-1*2.24}$
$x=1.76$. or $x={+4\pm-1*-2.24}=6.76$
Correct? :)
FAQ: Width of a rectangular frame in terms of x.
What is the formula for the width of a rectangular frame in terms of x?
The formula for the width of a rectangular frame in terms of x is w = 2x, where w represents the width and x is the variable.
Does x represent the length or the width of the frame?
X can represent either the length or width of the frame, depending on how the frame is oriented.
How do you calculate the width if the length is given?
If the length of the frame is given, you can calculate the width by dividing the length by 2, since the width is half of the length in this formula.
Can the width of a rectangular frame be a negative value?
No, the width of a rectangular frame cannot be a negative value. It represents a physical measurement and cannot be less than 0.
Is there a specific unit for the width in this formula?
The unit for the width will depend on the unit used for x. If x is measured in inches, then the width will also be in inches. It is important to use consistent units in the formula for accurate calculations.
