Width of Spectrum produced by a prism?
In summary: D = n_F = n_C##Since the dispersion is expressed in terms of the Abbe number, it is necessary to know the wavelength of the light being dispersed in order to calculate the Abbe number.
itsnaresh
How to calculate the width of spectrum produced by a dispersive prism of a given apex angle and refractive index, of white light of given width incident on first face of prism?
If by spectrum you mean the frequency content of the light, then the spectrum width after passing through the prism is the same as that before entering it, assuming the propagation inside the prism is of linear nature. On the other hand, if you mean the width of the visible color spread, which is not the same as the spectrum defined previously, then you also need to specify the distance from prism back surface to the observation plane and the tilt of this plane. Rather than going through the trouble of specifying these parameters, it's much simpler to calculate the angular spread instead.
Likes davenn
Thank you very much for your reply. I am attaching below two pictures. The top picture shows the spectrum produced on a screen by a prism when white light is incident on its first face. Spectrum produced on the screen has distinct widths of various colors from red to blue. I want to know how we can calculate these widths of various colors when a collimated beam of white light is incident. The second pictures shows the layout of the system. I can work out the dispersion for various colours having different colours for a single ray. But I can not work out for the beam. Actually I want to design a wavelength scale for this system. The parameters Fo, D and X can be fixed based on the calculations.
UOI9SJUk_HOcvBsXOphVf6Okpb7rtSUD5bGUKriQEWHOVfM0ETeGrqU8P_gBK_2OeaaPCvGhz_7De7ZjseyB=w1024-h635.jpg
  • UOI9SJUk_HOcvBsXOphVf6Okpb7rtSUD5bGUKriQEWHOVfM0ETeGrqU8P_gBK_2OeaaPCvGhz_7De7ZjseyB=w1024-h635.jpg
You list a single refractive index, but of course the refractive index depends on the wavelength. The diffraction angle is just given by Snell's law. ##n_1 \sin \theta_1 = n_2 \sin \theta_2##.
The Abbe number approximately characterizes the dispersion with just a single number.
Looking at this https://en.wikipedia.org/wiki/Abbe_number#/media/File:Abbe-diagram_2.svg , it looks like the Abbe number for SF1 is around 29.5.
Wikipedia says
##V_D = \frac{n_D-1}{n_F-n_C}##
where nD, nF and nC are the refractive indices of the material at the wavelengths of the Fraunhofer D-, F- and C- spectral lines (589.3 nm, 486.1 nm and 656.3 nm respectively)
So, that means
##29.5 \approx \frac{1.717295-1}{n(486.1)-n(656.3)}##
##n(486.1)-n(656.3) \approx 0.024315##
##\frac{dn}{d\lambda} \approx -1.4286 \times 10^{-4} \mathrm{cm}^{-1}##
Just plug that into Snell's law based on the geometry of your prism.
Related to Width of Spectrum produced by a prism?
1. What is the width of the spectrum produced by a prism?
The width of the spectrum produced by a prism depends on the properties of the prism, such as the material it is made of, the angle of incidence of light, and the angle of the prism. Generally, the width of the spectrum is between 30-60 degrees.
2. How does a prism produce a spectrum?
A prism works by refracting or bending light as it passes through the different angles of the prism. This causes the different wavelengths of light to separate, resulting in the formation of a spectrum.
3. Can the width of the spectrum be changed by altering the properties of the prism?
Yes, the width of the spectrum can be changed by altering the properties of the prism. Changing the angle of incidence or using a prism made of a different material can affect the width of the spectrum produced.
4. Is the width of the spectrum always the same for different types of light?
No, the width of the spectrum can vary for different types of light. This is because different types of light have different wavelengths, and a prism separates light based on its wavelength.
5. How does the width of the spectrum relate to the colors of the rainbow?
The width of the spectrum produced by a prism contains all the colors of the rainbow, which are red, orange, yellow, green, blue, indigo, and violet. The width of the spectrum is wider than the visible colors of the rainbow, as it also includes infrared and ultraviolet light.
