A Wiesendanger's quantization of an SO(1,3) extension of GR
dextercioby
Insights Author
TL;DR Summary
Wiesendanger's theory of SO(1,3) gravity is quantized and proved renormalizable. Is it a real deal?
Are you aware of the 3-article series of Wiesendanger's quantized extension of GR?
This is open access: C Wiesendanger 2019 Class. Quantum Grav. 36 065015 and the two sequels linked to in the PDF. The question is if this work counts as a quantization of a reasonable extension or reformulation of GR.
What is your opinion?
dextercioby said:
Summary:: Wiesendanger's theory of SO(1,3) gravity is quantized and proved renormalizable. Is it a real deal?
Is there any indication that it’s testable?
There are no „standard QFT” observables, nor phenomenology computed/derived, only questions asked as where to next from the a-la-Standard Model quantization that he provided for his SO(1,3) gauge theory.
The last step to be taken in consistently quantizing the SO(1,3) gauge field theory at hands,
and hence potentially gravitation, will be the demonstration of the unitarity of the S-matrix on
the physical Fock space for the gauge field.
And then more work starts: what about asymptotic freedom versus the observability of the
gravitational interaction—or the β-function of the theory determining the running of the gauge
coupling?What about instantons which definitely exist in the Euclidean version of the theory
given that SO(4)=SU(2)×SU(2), and anomalies?And what about the interplay of S(2)
G and
S(4)
G whereby the former dominates the gravitational interaction at long distances or in the
realm of classical physics and the latter at the short distances governing quantum physics? And
what about the gravitational quanta implied by the latter already in the non-interacting theory?”
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
