- 10,337
- 1,515
Wikki says the following with respect to Unruh effect:
http://en.wikipedia.org/w/index.php?title=Unruh_effect&oldid=563459371
I'm not at all sure it's accurate though.
I seem to be getting myself more confused as I try to think about this, starting with the issue of whether the temperature of a classical fluid in an Einsten's elevator should actually be uniform with height or not.
The Unruh effect could only be seen when the Rindler horizon is visible. If a refrigerated accelerating wall is placed between the particle and the horizon, at fixed Rindler coordinate \rho_0, the thermal boundary condition for the field theory at \rho_0 is the temperature of the wall. By making the positive \rho side of the wall colder, the extension of the wall's state to \rho>\rho_0 is also cold. In particular, there is no thermal radiation from the acceleration of the surface of the Earth, nor for a detector accelerating in a circle[citation needed], because under these circumstances there is no Rindler horizon in the field of view.
