Will a body ever escape in a 3 body problem?
In summary, Stephen Wolfram discusses the Three-Body Problem and its unpredictability in a lecture at about 54:10. The problem refers to the inability to accurately predict the future positions of three bodies due to the sensitive dependence on initial conditions and the intrusion of quantum mechanical effects. While it is possible for one of the bodies to escape towards infinity, there is no general way to predict when or if this will happen. However, simulations can be run to see ejection and capture events, and certain initial conditions can give an indication of potential ejections or collisions. Ultimately, the laws of physics demonstrate that ejections are possible, but the exact timing and occurrence cannot be proven in all cases.
dynawics
I am asking this question because I found it in a lecture by Stephen Wolfram which you can see at this link at about 54:10:
Apparently the question cannot be answered with current methods of physics- Wolfram describes it as "undecidable". But what is the question? When he says "escape" does he mean escape velocity? Does he mean that it is impossible to determine the escape velocity of a body in a three body problem? Or is it something else?
Thanks.
Google for three body problem, e.g. http://en.wikipedia.org/wiki/Three-body_problem.
There is no way to write down a formula for the future position of the three bodies in the general case. That's been known since 1887. One can write programs to simulate the motion and predict the positions, but as one tries to predict farther and farther into the future, the required accuracy becomes larger and larger. No matter how good the hardware, there will be a future time beyond which that hardware cannot make usefully accurate predictions. That is assuming one knows the starting positions, masses and velocities with perfect accuracy.
The orbital patterns have a sensitive dependence on initial conditions. In order to make a prediction, one has to known the initial data precisely. The farther futureward one tries to predict, the more accurate the input data must be. Eventually quantum mechanical effects intrude and sufficiently accurate measurements are impossible.
It is possible without violating conservation of momentum or energy or any of the rules of classical Newtonian physics for the three bodies to orbit around each other in such a way that one of the three is eventually ejected -- escaping toward infinity. What Wolfram is likely saying is that there is no general way to predict when (or if) this will happen.
My understanding is that, barring collisions and certain known special cases, such an escape it is almost certain. But I could be wrong on that.
Likes |Glitch|
How then is it possible to know that it is possible for a body in such a system to escape if we can never prove when or if it does so? Are there special cases in which we can prove that one body escapes and thus affirm this possibility- but then in other cases we simply lack the methods to prove if or when this possibility will occur?
We can run simulations and see ejection events where one object escapes to infinity. My understanding is that no special setup is required. We can run simulations and see that capture events occur. Since the laws of physics are time-reversible, those also demonstrate that ejections are possible.
There are many properties of an initial condition that allow us know what will happen with certain approximation before running a simulation: Virial Theorem!
Initial conditions means, mases, positions and velocities. From this we obtain initial Potential Energy, Kinetic Energy, Angular Impetu. When there is a lot of Kinetic Energy chances are that ejection will occur because gravity will not be enough to retain the bodies in orbit. When velocities are too small then Kinetic Energy is not enough to prevent gravity to cause a collision between two bodies. Remember that velocity is a vector that means that its direction also determines the output, for example, no matter how high speed two bodies have if they travel one toward the other they will collide. Also, there is a minimum speed at which if the three bodies are directed in opposite direction of the center of mass they will escape even their speed gradually decreases reaching a zero speed at infinitum. If with this minimum speed they are directed in other direction one collision or ejection would occur.
Dang me. I was just going to suggest that! Grrrr.
Related to Will a body ever escape in a 3 body problem?
1. Will a body always remain in orbit in a 3 body problem?
No, a body may escape from the orbit in a 3 body problem under certain conditions.
2. What are the conditions for a body to escape in a 3 body problem?
A body may escape in a 3 body problem if it reaches a critical speed known as the escape velocity, or if it experiences a close encounter with another body that changes its trajectory.
3. Is it possible for all three bodies to escape in a 3 body problem?
Yes, it is possible for all three bodies to escape in a 3 body problem if they reach the escape velocity or experience close encounters with each other.
4. How does the mass and distance between bodies affect the possibility of escape in a 3 body problem?
The mass and distance between bodies play a significant role in determining the possibility of escape in a 3 body problem. Generally, the larger the mass and closer the distance between bodies, the higher the chance of escape.
5. Can a body escape and then return to the system in a 3 body problem?
Yes, it is possible for a body to escape and then return to the system in a 3 body problem. This can occur if the body has enough energy to escape, but then gets pulled back into the system due to the gravitational pull of another body.
  • Other Physics Topics
  • Classical Physics
  • Science Fiction and Fantasy Media
  • Beyond the Standard Models
