- #36
- 10,318
- 1,489
dagmar said:Oh , yes please do so, for the elevator example that you have given us and please announce the results!
See https://www.physicsforums.com/threads/the-notion-of-weight-in-relativity.701257/#post-4445483 where I worked it out in the past.
The problem is worked out by describing Superman's position in inertial coordinates (t,x,y,z) using geometric units where c=1. In the initial problem, though, Superman is replaced by a sliding block. Einstien's train is also a good choice for the moving object.
One thing that's a bit confusing about this post when I re-read it is that I introduced a parameter K to describe superman's velocity. The relation between K and superman's normalized velocity ##\beta_0## and K is that
$$K = \beta_0 / \sqrt{1-\beta_0^2} \quad \beta_0 = K / \sqrt{1+K^2}$$
also useful is the relationship ##\gamma_0 = 1/\sqrt{1-\beta_0^2} = \sqrt{1+K^2}##
The relation between ##\beta_0## and K can be and is derived from the original post by computing ##dx/dt =\frac{dx/d\tau}{dt/d\tau}## at t=0.
I use the notation ##\beta_0## because Superman's velocity in the x direction in the inertial frame varies with time. Superman's momentum in the x-direction stays constant, and so does his velocity relative to the floor of the rocket. But the x-component of his velocity in an inertial frame of reference does not stay constant. However, at t=0, the elevator is at rest, and superman's velocity relative to the elevator floor is the same as his velocity in the inertial frame of reference.
Another thing that would be helpful to show is that Superman's motion is hyperbolic motion, but I didn't do that in that thread. Note that while it is hyperoblic motion, Superman's proper acceleration is different from the proper accleration of the elevator.
It seems to me there should be an easier way to do this, but I didn't find it, so I'll stick with what I've already done.
