Will high power laser penetrate mirror?
In summary, this new material that reflects 100% of incident light has been discovered. This could be a key breakthrough in designing more powerful lasers.
lemd
31
Many nations are developing hi-energy laser weapon. My question is, what if target is coated with mirror like coating? Can laser (since laser is still light) penetrate mirror? If it can then how is it possible?
Regards
Science news on Phys.org
Well mirror is just like any other material , the difference is that the coating of the mirror is of such material that has a very smooth surface and other characteristics that tend to reflect incoming EM radiation in the visible spectrum.In other words light.
Now I am no mirror specialist but I do bet that nothing is pure so a mirror too absorbs some of the light (radiation) that's coming in it's way so with time it could heat up and break or other problems could arise.
I'm sure others will comment more on this.
I think key factors here are the wavelength of the laser light and the intensity.
the trick around most of that problem would be to have the reflective surface on the front of the glass, as is done with telescope mirrors. That way the laser isn't passing through the glass
Dave
Yes I could agree but the material which reflects also absorbs something or are there materials that reflect 100% of some wavelength light? Although I don't think so.
You are correct. There are no perfectly reflective materials. If the reflector is 99% efficient then the laser trying to penetrate it has to be powerful enough that 1% of it's energy will have the desired effect on the target. 1 big reason that this is technically difficult is that the laser itself absorbs some of its own energy so you wind up with as much destructive energy (heat) being produced within the weapon as you are delivering to the target. Add to that the fact that the beam will diverge between the weapon and the target so the energy will be more concentrated (destructive) at the weapon end of the beam.
+ add the efficiency of a typical even the best laser, and you get everything but not a weapon of choice.Despite all the fantasy movies and all the pretty red glowing stuff that people like so much.
I use a laser cutter that cuts through silvered acrylic, I think it is an infra red laser, 30mW.
Silver is only some 98-99% reflective for infrared, and less at lower wavelengths. The mirror will heat up and eventually burn off. If it's a thin mirror, it won't take much heat before failing.
On the other hand, you can use thin films to increase reflectivity higher than 99%, but the thin films are even more easily destroyed.
No material is perfectly conducting and so there will always be some penetration of the laser field into the reflecting medium.
For mirrors that are more than ~100 nm thick, the limiting factor to power reflectivity will likely be thermal damage due to absorption.
Claude.
During the cold war there was much discussion about putting high powered lasers in orbit in order to shoot down incoming missiles. The problem is that high powered lasers are massive and not easily aimed. The solution was to use mirrors to aim the laser but that put a limit on the maximum reflectivity of the missile. At some point the aiming mirror would melt before the missile.
Surprise! This new discovery shows that some materials reflect 100% of the incident light!
"Perfect mirror debuts
Material that reflects light without letting any escape could improve lasers
Physicist Chia Wei Hsu and colleagues at MIT weren’t looking to invent a mirror when they were studying the behavior of light interacting with a photonic crystal, a slab of material with a network of drilled holes, each so small that it can manipulate individual light waves. Most of the time, light penetrated at least partially into the team’s crystal, a block of perforated silicon nitride. But when the researchers shined a specific frequency of red light at a 35-degree angle to the surface of the slab, they were surprised to find that it bounced back completely — none of it leaked away or got absorbed."
http://www.sciencenews.org/view/generic/id/351485/description/Perfect_mirror_debuts
FAQ: Will high power laser penetrate mirror?
Can a high power laser penetrate a mirror?
Yes, a high power laser can penetrate a mirror. However, the level of penetration will depend on the power and wavelength of the laser, as well as the type and quality of the mirror.
How does a high power laser penetrate a mirror?
A high power laser is able to penetrate a mirror because mirrors are not 100% reflective. They reflect a portion of the light that hits them, but also absorb and transmit some of the light. The level of penetration depends on the amount of light absorbed and transmitted by the mirror.
What type of mirrors can a high power laser penetrate?
High power lasers can penetrate most types of mirrors, including glass, metal, and optical mirrors. However, some mirrors may be specifically designed to reflect certain wavelengths of light and may be more difficult to penetrate with a high power laser.
Can a high power laser damage a mirror?
Yes, a high power laser can potentially damage a mirror if the power and wavelength of the laser are high enough. The intense heat and energy from the laser can cause the mirror to melt, crack, or shatter.
Is there a limit to the power of a laser that can penetrate a mirror?
Yes, there is a limit to the power of a laser that can penetrate a mirror. As the power of the laser increases, the chances of damaging the mirror also increase. Additionally, the higher the power, the more difficult it may be to focus the laser to a small enough point to penetrate the mirror.
