chipmunk22
- 15
Will the spectra of the transmitted and received signal be different as a result of multipath reflection and noise?
MedievalMan said:Thanks for the better explanation.
Indeed, Image Processing was a fun class. By the end of the class, you made a program in C++ that was a mini-photoshop, with your own custom filtering routines! :)
a. sine will give you are response at a specified frequency => no good.chipmunk22 said:Thanks for the explanation!
Another qn, which of the following is the best technique to measure the response of an audio equalizer?
a. input known sinusoid, measure output, change freq and repeat
b. input impules, measure output, change freq and repeat
c. input unit step, measure output, change freq and repeat
d. all gives the same result
chipmunk22 said:For measuring the response, my ans is (d). I feel that it shd be ok to input either sinusoids, impulses or even unit step. although the best approach will be to use a sinusoid, bcos using impulses may have a tendency to spoil the loudspeaker. correct me if I'm wrong.
As for the qn on multipath, am i right to say that since multipath distorts the phase spectrum, but do no changes to the amplitude spectrum?
A signal spectrum is a representation of the different frequencies present in a signal. It shows the intensity or amplitude of each frequency component.
The spectra of transmitted and received signals can be different due to various factors such as interference, noise, and signal distortion during transmission.
The difference in spectra of transmitted and received signals can result in errors and loss of data during transmission. This can impact the accuracy and reliability of the data being transmitted.
Yes, the difference in spectra of transmitted and received signals can be minimized through various techniques such as using better transmission channels, signal processing, and error correction codes.
Yes, studying the spectra of transmitted and received signals is important for understanding the behavior of different types of signals and their transmission. It has practical applications in various fields such as telecommunications, radar systems, and wireless communication.
