Will this rope break due to the tidal forces or not?
In summary, the conversation discusses the scenario of a metal sphere tied to a rope on the surface of the Earth, orbiting a black hole at its Roche radius. The question is whether the rope will break when the Earth orbits the black hole even closer, causing a difference in gravitational acceleration (Δa) of 10.8 m/s2. The experts state that at this acceleration, the Earth will break due to its tensile strength being exceeded, regardless of the material it is made of. They also clarify that even solid steel would not be able to withstand this amount of tidal gravity, indicating that the Earth will disintegrate long before the rope breaks.
Hurricane939
23
While I was thinking about how tidal forces can make objects float at the surface of a planet orbiting a massive object like a black hole, the fact that any material on the Earth isn't held together by gravity only, but also by chemical bonds which give it its tensile strength came into my mind.
The scenario I thought of is as following:
1- A 10 kg metal sphere is tied to a 1 meter long thin rope and this rope is nailed into the surface of the Earth.
2- The tensile strength of the rope is 10 N. (So the metal sphere has to accelerate at 1 m/s2 to break the rope)
3- The Earth is orbiting a black hole at its Roche radius, and so our metal sphere on the surface of the Earth is effectively weightless and floating, but it is still held by the rope.
Here is a simple picture to summarize:
Now, if we move the Earth to orbit the black hole even closer until the tidal forces on Earth due to the black hole become Δa = 10.8 m/s2 and so the metal sphere is pulled by the difference between Δa and the Earth's gravitational acceleration (9.8 m/s2) which is 1 m/s2 towards the BH, will the rope break or not ?
In other words, if a is the gravitational acceleration towards the BH, in order to break the rope, which one do we need ? :
1- a (Point A) - a (Point B) = 1 m/s2
OR
2- a (Point A) - a (Point C) = 1 m/s2[/SUP]
(1), which also means at the Roche radius the sphere is safe for reasonable black hole sizes (Roche limit not much smaller than the diameter of Earth). The distance (CB) has a tidal gravity of 10m/s^2 there, and the Earth is huge.
The sphere still gets attracted by Earth, which provides 100 N of force in addition to the (maximal) 10 N from the rope, so between A and C you can have up to 11 m/s^2 tidal gravity.
I am sorry. The question was not complete and so I edited it. Please read it again.
In any case, I am trying to figure out how far a solar mass black hole has to be to break that rope.
I have calculated that if the difference in the gravitational acceleration between the surface and the center (I named this Δa) is 10.8 m/s2, then the sphere will be accerelating at 10.8 - 9.8 = 1 m/s2 towards the black hole, which is enough to break the rope. isn't that correct ?
Well, at 10.8 m/s^2 it is just at the breaking point. To be more precise, we would have to consider the different centrifugal/centripetal force as well, and add it to the gravitational attraction.
Long before the rope breaks, the Earth will disintegrate.
Could you please explain why that would happen ?
The Earth breaks as soon as the tidal gravity between C and B is 10m/s^2, or 10 m/s^2 over a distance of 6370 km. That corresponds to a tiny 1/637000 m/s^2 tidal acceleration over the length of the string, or 1/637000 of its critical tidal acceleration, again assuming the black hole has a reasonable mass (1 stellar mass is more than sufficient).
Actually, Earth would even break a bit earlier: the tidal forces deform it, which reduces the gravitational binding and increases the tidal forces. The Roche limit for liquids is further outside compared to the Roche limit for solids.
But the Earth is not bound only by its gravity, the rocks have tensile strength and so at 10 m/s2, free objects on the surface of the Earth will be floating, but the Earth itself will be bound by its rocks tensile strength.
You could arguethat the tensile strength is small compared to the force due to the difference in acceleration, but it would still have to be more than 10 m/s2
Tensile strength is negligible. Let's imagine Earth is made out of solid steel, which is certainly much stronger than rock. Ignore that its mass would increase, I just want to get a number for tensile strength and there is none for generic rocks. Steel has a tensile strength of ~500 MPa, a bit more or less depending on the type of steel, and a density of about 8g/cm^3. That gives a breaking length of ~6.5 kilometers at 10 m/s^2. If we have tidal gravity of 10.5 m/s^2 between core and surface, stress exceeds the tensile strength at a depth of around 150 to 200 km. That is a small fraction of the total size of earth, so it easily rips apart the whole Earth into multiple pieces, even 10.1 would be sufficient for that (with steel!). Apart from a tiny crust, most of the interior of actual Earth is liquid, with a tensile strength way below that of solid rock, which again is way below the tensile strength of steel. 9.81m/s^2 would be more than sufficient, as the Earth starts to deform below that value.
In page 33 here: http://pangea.stanford.edu/~jack/GP170/MarkZoback.pdf you can find that Sandstone, Marble, Limestone and Granite have tensile strengths around 10 MPa.
I couldn't understand what you meant by breaking length and how you got 150 to 200 km depth. Could you please explain that so I can apply it to the new tensile strength of rocks we just got ?
The breaking length is just a handy conversion tool: it is the maximal length of a cable suspended in a gravity of 10m/s^2 (or 9.81 if you like, I'll use 10 everywhere here) before it breaks. This is just tensile strength divided by density and gravitational acceleration: ##L=\frac{TS}{\rho g}##. Reduce g to 1/20, and L increases by a factor of 20, for steel from 6.5 km to 130 km. You can consider the material around B as an extremely thick "cable" suspended from the material to the left. This "cable" has a diameter that depends on depth, so it is a bit stronger - I approximated this by increasing the number to 150 to 200 km. It is just an order of magnitude estimate anyway.
10 MPa reduces all length scales by a factor of 50, so even your massive block of granite (the Earth is not such a single block) fractures into pieces of a few kilometers length easily long before the short rope breaks.
Ok great. This is actually why I asked this question, but there is still one thing that confuses me. First of all, let's keep the Earth gravitational acceleration at 10 m/s2 as you said.
The thing that confuses me is what "g" I should use in the breaking length.
For example, if we have tidal gravity of 10.5 m/s2 between core and surface, then everything at the surface has a gravity of 10.5 - 10 = 0.5 m/s2 away from the Earth.
Now, if I want to calculate the length of the rock column that should break due to this tidal gravity difference, should I use g = 0.5 m/s2 in the breaking length equation, OR "g" must be less because the the difference in gravity is between the surface and core and NOT between the beginning and end of the rock column ?
Ah, that's a detail I forgot to mention. Tidal gravity is approximately linear with distance, and gravitational force in the same direction is completely linear for a homogeneous sphere. The Earth is not homogeneous, but let's assume it would be. So if you are at 0.9 to Earth radius, you have 0.9 times the tidal acceleration, but also 0.9 times the gravitational force. If tidal gravity wins anywhere, it wins everywhere.
That gives a reasonable approximation, as long as the breaking length is not similar to the size of Earth.
That's perfect. Let me summarize what I understood and please correct me if there is something wrong.
If, for example, the acceleration of the surface due to the black hole is 20.5 m/s2 and the acceleration of the center due to the black hole is 10 m/s2, then the tidal gravity between core and surface is 10.5 m/s2 and free objects at the surface are being accelerated towards the black hole at 0.5 m/s2.
This would mean that the breaking length (L) = 75 kilometers. So very roughly, we should expect that at these tidal gravity conditions, chunks of rocks the size of 75 km or more should break from the Earth.
Is that correct ?
Chunks of 7.5 km if the Earth would be a solid piece of rock.
Actually, the chunks could have up to twice that size, then the middle is just at the limit of breaking. A bit more if we assume they are thicker in the middle.
Yeah, something like that.
Edit: fixed the factor 10 (see below)
Yea I am by no means trying to get accurate results. I am just try to get a general idea of how large there chunks can be.
Thank you very much for explaining all this.
I am sorry, it seems I have made a mistake calculating the breaking length.
In case of tidal gravity between core and surface of 10.5 m/s2, the breaking length is 7.5 km rather than 75 km.
Oh, right.
Well, the conclusion is that Earth won't reach this point in one piece, unless it is heading very fast towards the black hole.
Yes, exactly.
There is one last question that came to my mind while thinking about this.
As you can see, we found that a chunk of 7.5 km should be ripped from the Earth if the tidal gravity between the core and surface is 10.5 m/s2.
Now, by using the conditions that lead to this tidal gravity, I calculated the tidal gravity between the surface (the top of the 7.5 km chunk) and a point 7.5 km deep (the base of the 7.5 km chuck), that result was 0.012 m/s2, which is clearly not enough to break this chuck.
So is the tidal gravity between the top and base of the chuck irrelevant when calculating the size of the chuck that should be broken ?
In other words, are our calculations of 7.5 km chunk correct even though the tidal gravity over the length of the chunk is only 0.012 m/s2 ?
Hmm, good point, breaking up Earth means the different parts accelerate relative to the center of Earth, which reduces tension in those parts. So we get larger chunks.
Will this increase be so significant that our used order of magnitude estimation will be meaningless or it is not that significant ?
I would expect some square root thing. sqrt(6.5 km * 6370 km) = 200 km. Tidal acceleration is down by a factor of 30 (compared to the previous calculation) but mass is up by a factor of 30 (again compared to the previous calculation).
Now we are back to the same point that is confusing me.
Which tidal gravity difference is causing the breaking, between the surface and center or over the length of the rock column ?
Also, how large will the chunk be in our new case ?
Tidal gravity between material and the center-of-mass motion of whatever object this material is bound to.
Should be of the order of 200 km.
So it's the tidal gravity difference between the 200 km chunk and the center of the Earth that will cause the breaking. Is that correct ?
If the 200 km thing is still connect to more stuff, it will break, sure. Even worse: those 200 km are more along the line of the maximal size that can stick together under this tidal gravity.
So in this situation, we don't need to look at the tidal gravity over the length of the 200 km chunk, but rather on the tidal gravity between this chunk (its center of mass) and the center of the Earth since it is still attached to the Earth. right ?
Well, we found a method to determine if something breaks up at all. That is the 6.5 to 6370 km comparison, and indeed 6.5 < 6370. If it breaks, where does it break? That is a complicated thing, probably in the middle for a completely homogeneous material. It breaks there before we reach the point we considered. For the smaller chunks, we can ask the same question again. Technically, we would need to modify the gravitational forces, because suddenly some part of Earth is not there any more (or at least in some distance). But we can find an estimate for the largest object that can support its structural integrity for a given tidal acceleration. That's the 200 kilometers, as order of magnitude estimate.
Related to Will this rope break due to the tidal forces or not?
1. Will the rope break if it is tied tightly to a stationary object?
It is unlikely that the rope will break if it is tied tightly to a stationary object, as the force of the tidal forces will be distributed evenly across the rope. However, if the rope is already damaged or weak, it may be more susceptible to breaking.
2. How can I determine if the rope is strong enough to withstand tidal forces?
The strength of a rope is determined by its tensile strength, which is the maximum amount of force it can withstand before breaking. You can consult the manufacturer's specifications or perform a stress test to determine the rope's tensile strength.
3. Are there any specific factors that could cause the rope to break due to tidal forces?
Aside from the rope's tensile strength, other factors that could contribute to its breaking include the strength and direction of the tidal forces, the material and condition of the rope, as well as any external forces or objects that may be present.
4. Is there a way to reinforce the rope to make it less likely to break?
There are a few ways to reinforce a rope, such as using a thicker or stronger rope, adding knots to distribute the force, or using additional support structures. It is important to carefully consider the specific conditions and forces that the rope will be subjected to before reinforcing it.
5. Are there any alternative materials that may be more resistant to tidal forces than traditional ropes?
Yes, there are some materials that may be more resistant to tidal forces, such as steel cables or synthetic fibers like Kevlar. However, the strength and suitability of these materials will also depend on the specific conditions and forces that the rope will experience.
  • Astronomy and Astrophysics
  • Other Physics Topics
