Will this rotate like a Foucult's pendulum ? Why not ?
In summary, the conversation discusses the concept of Foucault's pendulum and its rotation in relation to the Earth's rotation. It is explained that a vertical rod with frictionless bearings will not rotate in a similar manner due to angular momentum conservation. The arrangement is not similar to a Foucault's pendulum as there is no pendulum axis to observe.
bksree
77
Hi
A Foucault's pendulum consist's of a heavy weight at the end of a long string with the string so suspended that it allows movement in any plane (eg. a string supported from a bearing fixed to the ceiling). The plane of the pendulum then rotates opposite to that of the Earth thus at the rate Ω * cosθ where θ is the co-latitude of the place.
Suppose a vertical rod is supported on frictionless thrust and radial bearings and placed on the ground.
Will this rod rotate in a similar manner ? If not, Why ?
TIA
If I understand your setup correctly, it will just continue to rotate at any initial rotation you give to the object (including 0 as option).
This is like Foucault's pendulum if you let it rotate in a circle - there is no (reasonable*) way to see the effect of a rotation.
*the angular frequency should depend on the direction of rotation, but the difference between those values is very small. Certainly not as nice as the original experiment.
I didn't quite understand what you said. My question is : The plane of the Foucault's pendulum will make a circular rotation in 24 h if it is carefully released and allowed to move without any twist of the cable (if it is directly above the N pole).
In a similar way, will the vertical pole arrangement also rotate if it is released without any angular velocity ?
TIA
Does your rod move like a pendulum? In that case, I don't understand the part "and placed on the ground". Can you draw a sketch?
If the rod moves like a pendulum, and if it is free to rotate around its pivot, it will show the same rotation of its pendulum axis.
Thank you for the reply. Please see the sketch in the attached file for the arrangement of the vertical rod.
TIA
  • FP.doc
I think it is like mfb said in his first post.
The rod will rotate at the same rate that you originally gave it.
At a pole, if you give the rod no rotation wrt the earth, the rod still has the same angular velocity as the earth, so you notice nothing measurable.
At other latitudes you might be able to observe some attempt at precession since the axis of rotation is changing direction as the Earth rotates.
That is not what I expected, but the result is the same: The rod will just continue to rotate with its (arbitrary) initial angular velocity.
The rod has no initial velocity. My question is : Will it rotate opposite to the Earth (like the plane of Foucault's pendulum) because it is supported on frictionless surfaces (bearings) ?
TIA
The rod has no initial angular velocity relative to what?
To an observer, rotating together with earth? It will stay like that, and rotate together with Earth as seen from space.
To an observer in space? It will stay like that, and rotate once per day as seen from earth.
Thanks for the reply.
The rod has no initial angular velocity w.r.t earth.
If the rod is located vertically in the N pole, why should not the rod rotate opposite to the Earth once per day as the Earth rotates underneath it ? The rod is supported on frictionless surface.
Isn't this arrangement similar to a Foucault's pendulum (upside down). The foucault's pendulum is hung from frictionless bearings allowing its plane to rotate, so shouldn't the same effect happen here also.
Angular momentum conservation. The rod will just keep its rotation.
It is not. You have no pendulum, and you do not look at the orientation of a pendulum axis (you cannot, as you do not have that).
Related to Will this rotate like a Foucult's pendulum ? Why not ?
What is a Foucault's pendulum?
A Foucault's pendulum is a device invented by French physicist Léon Foucault in 1851 to demonstrate the rotation of the Earth. It consists of a long pendulum suspended from the ceiling, with a weight at the end that swings back and forth. As the Earth rotates beneath the pendulum, the plane of its swing appears to rotate, providing evidence of the Earth's rotation.
How does a Foucault's pendulum work?
A Foucault's pendulum works due to the Coriolis effect, which is the apparent deflection of an object's path due to the rotation of the Earth. As the pendulum swings back and forth, the Earth rotates beneath it, causing the plane of its swing to slowly rotate. This rotation is imperceptible to the naked eye, but can be observed over time.
Will this object rotate like a Foucault's pendulum?
It depends on the object and its surroundings. A Foucault's pendulum works because it is suspended from a fixed point and has a long, heavy weight at the end. This allows the pendulum to maintain its motion without interference from outside forces. If an object is not suspended in this way, it will not rotate like a Foucault's pendulum.
Why doesn't this object rotate like a Foucault's pendulum?
As mentioned before, a Foucault's pendulum works because it is suspended from a fixed point and has a long, heavy weight at the end. This allows the pendulum to maintain its motion without interference from outside forces. If an object is not suspended in this way, it will not rotate like a Foucault's pendulum. Additionally, the size and weight of the object, as well as the environment it is in, can also affect its ability to rotate like a Foucault's pendulum.
Are there any other factors that can affect the rotation of an object like a Foucault's pendulum?
Yes, there are several factors that can affect the rotation of an object like a Foucault's pendulum. These include the location of the object on the Earth's surface (as the Coriolis effect is strongest at the poles), the height and length of the pendulum, and the amount of friction or resistance in the pendulum's suspension. Additionally, external forces such as wind or vibrations can also impact the rotation of the pendulum.
