William's question at Yahoo Answers regarding a 3rd order Cauchy-Euler equation
  • MHB
  • Thread starter MarkFL
In summary, the possible values of p for the given differential equation are -3, 1, and 2. This can be seen from the characteristic equation obtained after substituting the solution form into the ODE and solving for p.
MarkFL
MHB
13,288
Here is the question:
There are three linearly independent solutions of the differential equation?
There are three linearly independent solutions of the differential equation t^3y'''+3t^2y''-6ty'+6y=0 of the form t^p. Find the possible values of p.
a. 1,2,3
b. 1,2,-3
c. 1,-2,3
d.1,-2,-3
e. -1,2,3
f. -1,2,-3
g. -1,-2,3
h. -1,-2,-3
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello William,
We are given the linear ODE:
\(\displaystyle t^3y'''+3t^2y''-6ty'+6y=0\)
We are then told to assume that there are 3 linearly independent solutions of the form:
\(\displaystyle y(t)=t^p\)
Hence:
\(\displaystyle y'(t)=pt^{p-1}\)
\(\displaystyle y''(t)=p(p-1)t^{p-2}\)
\(\displaystyle y'''(t)=p(p-1)(p-2)t^{p-3}\)
Substituting into the ODE, we obtain:
\(\displaystyle t^3p(p-1)(p-2)t^{p-3}+3t^2p(p-1)t^{p-2}-6tpt^{p-1}+6t^p=0\)
Dividing through by \(\displaystyle t^p\ne0\) we obtain the characteristic equation:
\(\displaystyle p(p-1)(p-2)+3p(p-1)-6(p-1)=0\)
\(\displaystyle (p-1)(p(p-2)+3(p-2))=0\)
\(\displaystyle (p-1)(p-2)(p+3)=0\)
Hence, the possible values for $p$ are:
\(\displaystyle p=-3,1,2\)
This is choice b.).
FAQ: William's question at Yahoo Answers regarding a 3rd order Cauchy-Euler equation
What is a 3rd order Cauchy-Euler equation?
A 3rd order Cauchy-Euler equation is a type of differential equation that is used to model relationships between multiple variables. It is in the form of a polynomial equation with derivatives of different orders.
How is a 3rd order Cauchy-Euler equation solved?
The solution to a 3rd order Cauchy-Euler equation involves finding the roots of the characteristic equation, which is derived from the coefficients of the derivatives in the equation. The general solution is then found using these roots and the method of undetermined coefficients.
What is the significance of the Cauchy-Euler equation?
The Cauchy-Euler equation is significant because it can be used to model a wide range of physical phenomena, including oscillatory motion, electrical circuits, and heat transfer. It is also an important tool in solving more complex differential equations.
Can a 3rd order Cauchy-Euler equation have complex roots?
Yes, a 3rd order Cauchy-Euler equation can have complex roots. This is because the characteristic equation, which determines the roots, can have complex coefficients. In such cases, the solution will involve complex numbers and may require the use of complex analysis.
Are there any real-world applications of the 3rd order Cauchy-Euler equation?
Yes, the 3rd order Cauchy-Euler equation has many real-world applications. It is used in engineering to model vibrations in structures, in physics to describe the motion of a damped harmonic oscillator, and in economics to model population growth. It is also used in circuit analysis to determine the behavior of electrical systems.
