Wilson-Sommerfeld quantization to solve square-well potential
In summary, the Wilson-Sommerfeld quantization rule can be obtained from a zeroth-order WKB approximation. However, it only gives the correct result in the limit of an infinitely deep square-well potential, and for low potential depths, the error is substantial. This is because the rule does not take into account the exponential decay part of the wave function beyond the wall, which is present in solutions of finite wells but not in an infinite well. This implies that there may be a hidden step in the calculation that assumes the wave function at the turning points is zero, while in reality it is a linear combination of sine and cosine terms. Another explanation could be that the correctness of the quantization rule does not necessarily imply the correctness of
Robin04
260
TL;DR Summary
Applying the Wilson-Sommerfeld quantization rule to solve the square-well potential problem
The Wilson-Sommerfeld quantization rule claims (##\hbar=1##)
$$\frac{1}{2\pi} \oint p(x)\,dx=n,\,n=1, 2, ...$$
where integration is done in the classically allowed region. Applying this to a square-well potential with a depth of ##V_0## and width ##a##, we get $$E=\frac{\pi^2 n^2}{2a^2}$$
This only gives the correct result in the limit ##V_0 \rightarrow \infty##, and for low ##V_0## the error is quite substantial. I would like to understand why.
As I leant, the Wilson-Sommerfeld rule can be obtained from a zeroth-order WKB approximation. Let us consider a potential well described by a continuous function ##V(x)##, and pick two classical turning points ##x_1 < x < x_2##. In zeroth-order, the wave function can be given by
$$\psi_1 = exp\left( \pm i \int_{x_1}^x p\,dx\right)$$
but also as
$$\psi_2 = exp\left( \pm i \int_{x}^{x_2} p\,dx\right)$$
They have to be equal, and the real and imaginary parts yield the same result, namely, for the real part
$$\cos\left(\int_{x_1}^x p\,dx\right)=\cos\left(\int_{x}^{x_2} p\,dx\right)$$
Here comes a part that I don't understand ##(1)##: this implies that the sum of their phases have to be ##2\pi n##, from which
$$\int_{x_1}^{x_2}p\,dx=2\pi n$$
which is the desired result. The other part that I don't understand ##(2)## is that what step caused this result to only be valid for an infinitely deep square-well potential? I read about more detailed calculations that treat the regions around the turning points and those lead to the Bohr-Sommerfeld rule, which gives the correct result for a harmonic oscillator for example, but for this square potential it doesn't work at all. Can you help me figure this out?
Solutions of finite well have exponential decay part beyond the wall that the rule you mentioned does not include. Infinite well does not allow such permeation of wave function. I assume it is at least a part of reason to explain why.
That is true, but I assume there's a (hidden) step in this calculation that assumes that the wavefunction at the turning points is zero.
If you go further to WKB approximation this exponential dumping is considered.
Robin04 said:
Summary:: Applying the Wilson-Sommerfeld quantization rule to solve the square-well potential problem
I am afraid your method gives right wave function for harmonic oscillator. You say the correct result, it is of eigenvalue, wave function or any there features ?
I do not think ##e^{ipx}## cannot be zero at turning point mathematically.
Right wave function for harmonic oscillator? Those should be Hermite-polynomials, not simple exponentials, no? By correct result I mean eigenvalues.
I do not think ##e^{ipx}##cannot be zero at turning point mathematically.
That is true, but the ##\pm## in the argument means that it is a linear combination of a ##+## and a ##-## term. My writing was a bit misunderstandable, sorry. It can be sine and cosine, so it can be zero at the turning points.
Could it be that the correctness of the quantization rule obtained from the consistency of given-order WKB wave functions does not imply the correctness of the wave function itself? It wouldn't answer my question, but I would be one step closer, I guess.
Another idea: classically, the bound states in a square-well potential are independent of the depth of the well, while in quantum mechanics for a given level the wave functions take different values at the classical turning points for different depths. In zeroth-order, no quantum correction should appear, so one way of choosing consistent boundary conditions is to zero out the wavefunctions at the turning points. However, I still don't see how this appears mathematically here.
Related to Wilson-Sommerfeld quantization to solve square-well potential
1. What is Wilson-Sommerfeld quantization?
Wilson-Sommerfeld quantization is a method used in quantum mechanics to solve the Schrödinger equation for a particle in a potential well. It involves quantizing the classical action of the particle in the potential well, which results in a discrete set of energy levels.
2. How does Wilson-Sommerfeld quantization work?
In Wilson-Sommerfeld quantization, the classical action of the particle is quantized by imposing the condition that the action must be an integer multiple of Planck's constant. This leads to the quantization of the energy levels of the particle in the potential well.
3. What is the square-well potential?
The square-well potential is a simple potential function used in quantum mechanics to model a particle confined to a finite region. It is characterized by a constant potential inside the well and an infinite potential outside the well.
4. How is Wilson-Sommerfeld quantization used to solve the square-well potential?
To solve the square-well potential using Wilson-Sommerfeld quantization, the classical action of the particle in the potential well is quantized, resulting in a discrete set of energy levels. These energy levels can then be used to calculate the probability of finding the particle at different positions within the well.
5. What are the limitations of Wilson-Sommerfeld quantization for solving the square-well potential?
Wilson-Sommerfeld quantization is only applicable to simple potential functions, such as the square-well potential. It also does not take into account the effects of quantum tunneling, which can be significant for particles with low energy in the potential well. Additionally, it does not provide a complete description of the particle's behavior, as it only gives the energy levels and not the wave function of the particle.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
