Win the 3-Digit Lottery: Jackpots & Deuces!
  • Thread starter musicgold
  • Tags
    lottery
In summary: Ah! got it. I didn't realize that it is possible to pick the same ticket for 7 times, so the proportion of deuce tickets (12/35) doesn't change.
musicgold
304
This is not a homework problem. I am trying to understand an example given in a book.
It is about figuring out the chances of not getting a partial prize.
There is a 3-digit lottery that picks three numbers from the following: 1, 2, 3, 4, 5, 6, 7. The lottery has prizes for the jackpot and deuces. A ticket has a deuce when it has two of the three picked numbers. (see attached pictures if you want more context).
There are 35 possible combinations, and for every jackpot combination, there are 12 possible deuces (12/35). The book talks about a person buying 7 tickets of this lottery and claims that:
Chances of getting no deuces in the seven tickets = 5.3%
Chances of getting all 7 tickets being deuces = 0.1%
I tried to calculate the case of no deuces, but I couldn't get the correct answer. Here is what I did:
Chance of getting the first ticket with non-deuce values and the jackpot = 22/35
Chance of getting the second ticket ... = 21/34
and so on.
I got the following expression
$$ = \frac {22 } {35 } . \frac {21 } {34 } . \frac {20 } {33 } . \frac {19 } {32 } . \frac {18 } {31 } . \frac {17 } {30 } . \frac {16 } {29} $$
$$ = 0.025 $$
What am I missing?
Thanks
This doesn't make a lot of sense to me. If the tickets are different, then the probability of being a deuce is not independent for each ticket. With seven tickets you can guarantee getting at least one deuce.
The calculations carried out would apply to, say, buying one ticket on seven consecutive weeks. In that case, the tickets being deuce or not are independent.
Likes musicgold
PS I think he is assuming that you can pick the same ticket twice. That does make them independent.
Likes musicgold
I agree that the seven tickets can contain duplicates, so each ticket is independent (because I got 5.3% that way). Probably the mental model of the person writing the problem is you go into the gas station and they print you a ticket at random.
Also, note the first part only says no deuces, it doesn't say you can't have a jackpot.
Likes musicgold
The case is about buying multiple tickets of a draw. The book is discussing a case where some syndicates buy thousands of tickets of a draw. The example, is a simpler version of that. A person has bought 7 tickets of the 3-digit lottery and we are trying to see the chances of getting a deuce.
Okay, but one syndicate buying the same ticket twice doesn't make a lot of sense to me. Although, I suppose it depends on the rules of the lottery.
Likes musicgold
When there are 10 million possibilities (7 number lottery) and a syndicate buys 300,000 tickets using the quick pick option, there will be some duplicate tickets.
Also, here is the actual case the book is talking about:
https://www.theatlantic.com/business/archive/2016/02/how-mit-students-gamed-the-lottery/470349/
Given this, is my approach to calculating the no deuce probability incorrect?
Yes, see post #4.
Likes musicgold
If I exclude the jackpot number, then there are 23, non-deuce combinations.
$$ \frac{23 } { 35} . \frac{22 } {34 } . \frac{21 } {33 } . \frac{20 } {32 } . \frac{19 } {31 } . \frac{18 } {30 } . \frac{17 } {29 }. $$
$$=0.036 $$
what am I doing wrong?
$$=0.036 $$
You are assuming that each ticket you buy is different from the others. Although, in that case, whether one has a deuce or not is definitely not independent of the others.
Likes musicgold
I think the 5.3% assumes you do not attempt to coordinate the ticket picks. Each one is independently picked.
(23/35)^7 gives what you said is supposed to be the answer.
It doesn't seem like you're doing anything wrong other than the question being a bit confusing.
Likes musicgold
Thanks
Related to Win the 3-Digit Lottery: Jackpots & Deuces!
1. How does the "Win the 3-Digit Lottery: Jackpots & Deuces!" system work?
The system uses a combination of mathematical algorithms and statistical analysis to determine the most likely winning numbers for the 3-digit lottery. It takes into account previous winning numbers, frequency of number combinations, and other factors to generate a set of numbers with a higher probability of winning.
2. Is the "Win the 3-Digit Lottery: Jackpots & Deuces!" system guaranteed to win?
No, there is no guarantee of winning in any lottery system. However, the "Win the 3-Digit Lottery: Jackpots & Deuces!" system increases your chances of winning by selecting numbers with a higher probability of being drawn.
3. Can the "Win the 3-Digit Lottery: Jackpots & Deuces!" system be used for any 3-digit lottery game?
Yes, the system can be used for any 3-digit lottery game as long as the game follows a similar format and uses a 3-digit number combination.
4. How do I access the "Win the 3-Digit Lottery: Jackpots & Deuces!" system?
The system is available for purchase online. Once purchased, you will receive access to the system and instructions on how to use it to select your lottery numbers.
5. Has anyone won using the "Win the 3-Digit Lottery: Jackpots & Deuces!" system?
There have been numerous reports of individuals winning using the "Win the 3-Digit Lottery: Jackpots & Deuces!" system. However, as with any lottery system, individual results may vary and there is no guarantee of winning.
  • General Discussion
15K
