Wind Turbine Energy Transformations
In summary: Thermal energy from the friction encountered during the process. (from the rotation of the gears and such)This is not specific to wind turbines, it is a general property of machines.
Physics345
250
23
In point form, outline the process through which electricity is generated from a wind turbine, highlighting the energy transformations that occur. Then state an advantage for this type of electricity production that have not already been discussed in the lesson.
None
• The process starts with wind blowing which is the electric potential energy. The point of wind turbines is to capture the winds energy and convert it into energy in the form of electricity.
• While the wind blowing at a certain velocity the winds potential energy in the form of wind velocity which can be converted into kinetic energy.
• The kinetic energy from the winds velocity is converted into the turbine which begins to turn the blades in a horizontal circular motion, but it isn’t enough for just the wind turbines blades rotation to create mechanical energy, there is a shaft that connects to gears that rotate as well which creates even more rotation, which creates enough rotations per minute to convert that energy into mechanical energy (electricity). It is important to note the angle outer part of the blade adjusts according to the wind direction to allow the blades to spin relative to the wind in the most efficient matter.
• The kinetic energy is converted through a generator that produces the mechanical energy (electricity).
• The electricity current then travels through wires, which is then converted to power our cities light’s and pretty much anything requiring electricity as a form of power.
• A lot of energy is wasted in the form of thermal energy from the friction encountered during the process. (from the rotation of the gears and such)
Tell me what you guys think :)
Moving air does not constitute electric energy, potential or otherwise.
It is not potential energy either.
It may be converted by a turbine but it is surely not converted into a turbine.
What form of energy is that?
Horizontal?
Electrical energy is not considered an example of mechanical energy.
Likes Physics345
Horizontal?
• The process starts with wind blowing. The point of wind turbines is to capture the winds energy and convert it into kinetic energy.
• While the wind blowing at a certain velocity in the form of wind velocity which can be converted by the turbine, into kinetic energy when the blades rotate in a vertical circular motion.
• The kinetic energy from the wind is converted into the turbine which begins to turn the blades in a vertical circular motion (in the form of kinetic energy), but it isn’t enough for just the wind turbines blades rotation to create mechanical energy, there is a shaft that connects to gears that rotate as well which creates even more rotation, which creates enough rotations per minute to convert that energy into electricity. It is important to note the angle outer part of the blade adjusts according to the wind direction to allow the blades to spin relative to the wind in the most efficient matter.
• The kinetic energy is converted through a generator that produces electricity.
Okay I made some adjustments according to your comments :), let me know what you think thanks!
Better, certainly...
What sort of energy was it before it was captured?
This is not true, and is irrelevant to the question.
It is? Where do you get that from?
Most of the loss comes from a theoretical limit on the fraction of wind energy that can be captured. (Betz' law, I think it is called.). But again, you do not need to mention that.
That is also beyond what the question asks.
Hey sorry I haven't had the chance to come reply until now, I re wrote it according to your comments again.
• The process starts with wind blowing (solar energy). The point of wind turbines is to capture the winds potential energy and convert it into kinetic energy.
• The electricity is then converted to power our cities light’s and pretty much anything requiring electricity as a form of power.
Solar energy is the ultimate source of wind energy, but you are not asked about that. You still have not correctly identified the type of energy the wind has.
It is not that one.
As I already posted, it is not converted into a turbine. You might convert a frog into a prince but turbines are made of steel. It is converted in a turbine.
Anyway, you do not need this bullet. You already covered it in the preceding bullet.
You don't need this either. Two or three steps at the most.
Likes Physics345
It is not that one.
• The process starts with wind blowing ( The winds kinetic energy). The point of wind turbines is to capture the winds (kinetic energy) and convert it into kinetic energy that rotates the turbines in a vertical circular motion.
• The kinetic energy from the wind begins to turn the blades in a vertical circular motion (in the form of kinetic energy), but it isn’t enough for just the wind turbines blades rotation to create mechanical energy, there is a shaft that connects to gears that rotate as well which creates even more rotation, which creates enough rotations per minute to convert that energy into electricity. The kinetic energy is converted through a generator that produces electricity.
Just delete that phrase and what you have will be fine.
Likes Physics345
Perfect Thank you, for your help. I'm going to do more research to get a better understanding
The question sounds very much like one from my sons physics class. In which case you might get an extra mark/max marks by mentioning some of the unwanted energy transformations that occur.
When I took a look at the text I noticed something similar in the example of a question similar to this.
Related to Wind Turbine Energy Transformations
1. How do wind turbines convert wind energy into electricity?
Wind turbines have large blades that rotate when the wind blows. This rotation turns a shaft connected to a generator, which converts the kinetic energy of the spinning blades into electrical energy. The electricity is then sent to a power grid for use.
2. What are the different types of wind turbine designs?
There are two main types of wind turbine designs: horizontal-axis and vertical-axis. Horizontal-axis turbines have blades that spin around a horizontal axis, while vertical-axis turbines have blades that spin around a vertical axis. There are also variations within these two types, such as the three-blade design commonly seen in large, commercial wind turbines.
3. How efficient are wind turbines at converting wind energy into electricity?
The efficiency of wind turbines varies depending on factors such as wind speed, turbine design, and maintenance. On average, modern wind turbines have a conversion efficiency of 40-50%, meaning they can convert 40-50% of the wind's kinetic energy into electrical energy.
4. What happens to excess electricity generated by wind turbines?
When wind turbines generate more electricity than is needed, the excess energy is sent to a power grid and distributed to other users. This is why wind energy is considered a renewable source of energy, as it can be used whenever needed, unlike non-renewable sources like fossil fuels.
5. How does wind turbine energy compare to other sources of energy?
Wind turbine energy is a renewable and clean source of energy, meaning it does not produce greenhouse gas emissions that contribute to climate change. Additionally, wind energy is becoming increasingly cost-competitive with traditional sources of energy like coal and natural gas. However, the availability of wind energy is dependent on weather conditions, so it is not always a consistent source of energy.
  • General Engineering
  • Electrical Engineering
  • Mechanical Engineering
