How can I change a file's type in Windows XP?
  • Thread starter Thread starter bomba923
    File Type
Changing a file type in Windows XP can be done by renaming the file extension, similar to earlier versions of Windows. If files are not displaying their full names, users should adjust their folder settings by navigating to Tools -> Folder Options -> View tab and unchecking "Hide extensions for known file types." This allows users to change file extensions, such as from .htm to .wmv, enabling compatibility with applications like Windows Movie Maker. For .mov files from digital cameras, Windows Movie Maker does not support this format directly. Users are advised to install QuickTime Player for playback or use video conversion software to change .mov files to a compatible format like .avi. Recommended conversion tools include RAD Video Tools, TMPGEnc, and VirtualDub, which can facilitate the necessary format changes for editing in Windows Movie Maker.
bomba923
In earlier versions of Windows, all one had to do to change a file type is simply rename the extension. How, though, does one change a file's type in Windows XP?
For example, I have some downloaded video files that are listed as "htm" files. When opening them in Windows Media Player, I get a message saying that WMP might not recognize the file type. Ignoring the message, I ask WMP to play the file and it does so PERFECTLY (in other words, the media file has a wrong extension). I want to edit this file in Windows Movie Maker, but it "doesn't recognize the extension" (it doesn't even try to, unlike WMP). In earlier versions of Windows, all one had to was to rename the file's extension (from .htm to .wmv).
But HOW can I accomplish this in Windows XP?
Computer science news on Phys.org
You can change the extension to wmv just as you did in previous versions of Windows. It's no different.
Perhaps you don't have Windows set to show you the full filenames, however. Open up your folder, select Tools->Folder Options...->View tab and uncheck "Hide extensions for known file types." Click "Apply to All Folders" and you should be set.
- Warren
:smile: Thanks chroot! Now it works
I wonder if you could help. I am trying to do the same thing.
I upload a video from my digital camera, the file extension is .mov
I can't open this with windows moviemaker, it says the file type is not valid, even when I followed the steps above. Any ideas on what I can do so I can edit these in windows movie maker?
install quick time player
http://www.apple.com/quicktime/download/win.html
extensions mov work only with quick time player , while windows media player plays only avi, wmv etc , but not .mov
also there are converters that can make .mov into .avi or something else ... try finding "winavi" , but I'm not sure it's the exact program .
edit : after some browsing i found that - RAD Video Tools, TMPGEnc, VirtualDub , those programs can help you convert it to avi , so you can use it in the moviemaker , or you can see here http://www.alivemedia.net/videoconverter.htm for some download hint
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
