MHB Wire Length w/ 0.068 Ohms & 2.8mm Diameter: ~11.56 ft
The discussion focuses on calculating the length of a wire based on its resistance and diameter. The resistance of a wire is directly proportional to its length and inversely proportional to the square of its diameter. Given a wire that is 50 feet long with a resistance of 0.265 ohms and a diameter of 2 millimeters, the constant of proportionality, k, was determined to be 0.0212. Using this value, the formula for resistance was adjusted to find the length of a wire with a resistance of 0.068 ohms and a diameter of 2.8 millimeters. The calculations lead to the conclusion that the length of the wire is approximately 11.56 feet.
unicorngirl
The electrical resistance of a wire varies directly with the length of the wire and inversely with the square of the diameter of the wire. If a wire 50 feet long and 2 millimeters in diameter has a resistance of 0.265 ohms, find the length of a wire of the same material whose resistance is 0.068 ohms and whose diameter is 2.8 millimeters. The length of the wire is approximately ___ feet when the resistance is 0.068 ohms and the diameter is 2.8 millimeters. (Round to the nearest hundredth.)
Mathematics news on Phys.org
Hello and welcome to MHB, unicorngirl! :D
I have moved your thread, since this problem type is generally encountered in an algebra course, and not a calculus-based statistics course.
We are told:
So, if we define:
$$R$$ = resistance
$$L$$ = length
$$D$$ = diameter
We may then take the above sentence, and express it mathematically as:
$$R=k\frac{L}{D^2}\tag{1}$$
where $k$ is the constant of proportionality.
To determine $k$, we may use the given information:
A wire 50 feet long and 2 millimeters in diameter has a resistance of 0.265 ohms.
Plug the values into (1)...what do you find for the magnitude and dimensions for $k$?
Okay thank you! I wasn't sure where to post it.
I got .0212 for K. I hope I did that right.
Yes, the value you obtained is correct! (Yes)
We should at least be aware of the units for $k$:
$$k=\frac{D^2R}{L}=\frac{(2\text{ mm})^2(0.265\,\Omega)}{50\text{ ft}}=0.0212\frac{\text{mm}^2\Omega}{\text{ft}}$$
So now, using rational rather than decimal notation, we may state:
$$R=\frac{53D^2}{2500L}\tag{2}$$
Now, you have a question to answer:
Find the length of a wire of the same material whose resistance is 0.068 ohms and whose diameter is 2.8 millimeters.
So, solve (2) for $L$, and then plug in the given values for $R$ and $D$.
What do you find?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
