Wire strippers for duplex thermocouple wire?
  • Thread starter Thread starter DSal
A suitable wire stripper for type K duplex thermocouple wire is the Stripmaster series by Ideal Industries, which can offer custom blades for production environments. For one-time projects, a workflow that involves pulling all wires, stripping jackets with a razor knife, and then stripping conductors can be efficient. Implementing a template for jacket length and using strippers with a wire stop can save significant labor time. For production settings, powered wire strippers may be beneficial, especially for individual conductors. Contacting manufacturers for tailored solutions is recommended for optimal results.
DSal
Does anyone here know of a good wire stripper for type K duplex thermocouple wire?
Not specifically but, if you are in a production environment for this, the Stripmaster series by Ideal Industries (https://www.idealind.com) is a place to start (they can make custom blades if the volume justifies it).
If it is a one-time situation like instrumenting a room or a one-of-a-kind-machine, perhaps you can set up the work flow to:
Pull/route all wires
Strip all jackets (razor knife to split, dikes to snip it off)
Strip all conductors
It doesn't take much volume to justify:
1) Making a template for jacket length (even a piece of cardboard cut to length), and
2) Strippers that have a wire stop so you can insert wire to the stop and strip instead of having to make a judgement call on length every time.
Those two tips can easily save 20% to 30% of labor time.
(You may find something with this search:
https://www.google.com/search&hl=en&q=wire+stripper+for+duplex+wire)
Cheers,
Tom
Thanks Tom, yes these would be for a production environment. We are an OEM supplier of molten aluminum casting equipment, and require the use of T/C placement at various locations of our equipment in the melt stream itself. So looking to supply these tools to assist with our customers needing to make and remake these T/C wire junctions in as easy as possibly fashion, instead of just using dikes!
OK, since it really is a production environment you might investigate powered wire strippers; their are some that operate the same as an electric pencil sharpener.
They may not work well for the jacket of duplex wire, but could be quite useful for the individual conductors.
You best bet is to contact some manufacturers of wire strippers and ask what ideas (products) they have.
Cheers,
Tom
Yes, I have contacted Ideal Industries, and will be sending them samples of the exact wire we use and supply to our customers. Thanks again for your advice!
Likes berkeman, Tom.G and dlgoff
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
