Wish to understand the Venturi Effect WRT cooling
In summary, the A/C system in a vehicle works by using a compressor to reduce the pressure downstream of a constriction in the flow of refrigerant. This constriction causes the refrigerant to expand rapidly and cool as it exits and enters a larger diameter tube. The expansion and cooling is made possible by the highly compressible nature of the refrigerant flow. The static pressure decreases and the velocity increases through the constriction, causing the refrigerant to cool. The expansion takes place in the larger tube downstream of the constriction, where the static pressure is lower. This process is essential for the A/C system to function and is made possible by the use of a compressor and a constriction in the flow of refrigerant.
slay2k
Not a physics student -- but was thinking about how the A/C system works in a vehicle.
First surprise was that pressure drops when a tube narrows. Seemed counter-intuitive as I was picturing taking a balloon and squeezing it -- would the pressure in the middle be lower than the ends? Then again that's a closed system, but it affected my thought process.
Perhaps a garden hose is a better example. Sure, the water speeds up, but it certainly doesn't feel any easier to squeeze a garden hose (say a wide but flexible one) with water running through it. The more you squeeze, the harder it would get because you're constricting the flow -- is it not inner pressure making it harder and harder to squeeze?
Lastly, I understand that the refrigerant (R134a) in a cooling system needs to expand to cool, but I definitely do not understand how constricting it into a tiny section allows it to expand and become hyper-cooled gas.
A) Where is it expanding to? How is there sufficient room to expand in the constricted area? How does this not increase pressure?
B) If the total pressure in the system remains the same (dynamic increases, static drops?) then why is the refrigerant phase changing? In other words, if the total pressure remains the same then why does the boiling point decrease at all?
Apologies if the questions are stupid. Would really love to understand the most fascinating part of what makes A/C possible.
The refrigerant expands as it passes the constriction: its a nozzle and the tube after the constriction is larger than the constriction. Also, total pressure does not determine whether the phase (and temperature) changes: static pressure does.
But it expands within the constriction where the static pressure is lower, right? If so, how can it expand when the amount of space is fixed?
Also, is there an intuitive way to understand why only the static pressure affects the phase and temperature?
There's at least one pump in the A/C system where the intake of the pump takes in lower pressure gas from the region where the lower pressure and cooler gas is removing heat from the interior of the vehicle, and the pump outputs higher pressure and hotter gas to the radiator section where the heat is dissipated via the radiator to the ambient air outside. In this case, Venturi effect isn't being utilized. The constriction between the radiator and vehicle section opposite the pump restricts the flow (like a reverse pump), working in conjunction with the pump to maintain the low pressure and high pressure regions.
I'm familiar w/ the compressor (pump) and the condenser (radiator) components of the system. The Venturi effect exists in all of these systems, sitting between the condenser low-side and the in-cabin evaporator either in the form of a) a thermal expansion valve (dynamic flow control + Venturi) or b) orifice tube (Venturi only).
Without this drop in pressure and subsequent vaporization of the refrigerant liquid, A/C would not be possible.
I still don't have a full grasp of the process from a physics standpoint, however, specifically the questions in my last comment.
Something like flash evaporation makes sense to me, because there is space in the drum for the liquid to expand into. I don't know if this is what exists in the A/C system though?
Static pressure decreases as velocity increases and for a subsonic flow, the velocity increases through a constriction. So yes, the static pressure decreases in the constriction. This is not where the expansion and cooling takes place, however. The flow of refrigerant is a highly compressible process. The pressure downstream of the constriction is much lower than upstream and the flow is choked by the constriction. It therefore expands rapidly once it leaves the constriction, causing it to cool.
To follow up on boneh3ad's post:
The expansion is from the small diameter constriction to the much larger diameter tubing just downstream of the constriction. In this case there's an external force involved, the intake side of the compressor that is reducing the pressure downstream of the constriction, and the output side of the compressor that is increasing the pressure upstream of the constriction. So just downstream of the constriction, the highly compressible flow expands, cools, and slows down (versus it's velocity through the constriction).
slay2k said:
I'm familiar w/ the compressor (pump) and the condenser (radiator) components of the system. The Venturi effect exists in all of these systems...
The venturi effect is not well applied to any of these situations. The venturi effect doesn't deal with significant density changes, much less phase changes. It deals only with slight changes in pressure due to the velocity change and the low-speed version of Bernoulli's principle.
Related to Wish to understand the Venturi Effect WRT cooling
1. What is the Venturi Effect?
The Venturi Effect is a phenomenon in fluid dynamics where the velocity of a fluid increases as it passes through a constricted section of a pipe or tube.
2. How does the Venturi Effect relate to cooling?
In the context of cooling, the Venturi Effect is used to increase the flow rate of air or water through a cooling system. This increased velocity helps to dissipate heat more efficiently, resulting in a cooler environment.
3. What components are needed to create the Venturi Effect in a cooling system?
To create the Venturi Effect in a cooling system, you will need a constricted section of pipe or tube, a source of fluid (such as air or water), and a pressure difference between the two ends of the constricted section.
4. Can the Venturi Effect be used for both air and liquid cooling?
Yes, the Venturi Effect can be used for both air and liquid cooling systems. In air cooling, the constricted section of the pipe or tube is usually in the form of a nozzle, while in liquid cooling, it is typically a narrow channel or tube.
5. What are the benefits of using the Venturi Effect for cooling?
The Venturi Effect can provide more efficient cooling compared to traditional methods, as it increases the flow rate and therefore the rate of heat dissipation. It also allows for more precise control over the cooling process, as the degree of constriction can be adjusted to achieve the desired level of cooling.
  • Classical Physics
33K
  • Mechanical Engineering
  • Mechanics
  • Other Physics Topics
13K
