Wondering about hydrogen peroxide
In summary, hydrogen peroxide is a chemical compound that is commonly used as an antiseptic, bleaching agent, and oxidizer. It works by releasing oxygen that can kill bacteria and other microorganisms. While generally safe when used properly, it can be harmful if ingested or in high concentrations. Hydrogen peroxide has a variety of uses, including disinfecting wounds and as a household cleaner, but there is limited scientific evidence to support its use as a natural remedy. It should never be ingested and caution should be taken when handling it.
AutisticAlien
How does it bleach hair? My Chemistry professor at college told us about how chemical straightening works, but failed to explain how peroxide can change hair colour.
Thanks a bunch!
Chemistry news on Phys.org
Basically hydrogen peroxide destroys dye by oxidizing it. To check details you have to check what dye is present in hair. Melanin comes to mind as a good starting point in search.
Hydrogen peroxide is a strong oxidizing agent, meaning it has the ability to break down chemical bonds in substances. When applied to hair, it reacts with the melanin pigment molecules, which give hair its color. This reaction breaks down the melanin molecules, resulting in lighter or bleached hair. The concentration and duration of exposure to hydrogen peroxide will determine the extent of bleaching. Additionally, the use of heat or alkaline substances can enhance the bleaching effect. It's important to note that hydrogen peroxide can also damage the hair by breaking down the protein bonds, so it is important to use it carefully and in moderation. I hope this explanation helps clarify the process of hair bleaching with hydrogen peroxide.
Related to Wondering about hydrogen peroxide
1. What is hydrogen peroxide?
Hydrogen peroxide (H2O2) is a chemical compound made up of two hydrogen atoms and two oxygen atoms. It is a colorless and odorless liquid that is commonly used as an antiseptic, bleaching agent, and oxidizer.
2. How does hydrogen peroxide work?
Hydrogen peroxide works by breaking down into water and oxygen when it comes into contact with certain enzymes or other substances. This process releases oxygen that can help kill bacteria and other harmful microorganisms.
3. Is hydrogen peroxide safe to use?
When used properly, hydrogen peroxide is generally considered safe. However, it can be harmful if ingested or if it comes into contact with the eyes or skin in high concentrations. It is important to follow the instructions on the product label and to use caution when handling hydrogen peroxide.
4. What are the uses of hydrogen peroxide?
Hydrogen peroxide has a variety of uses, including as a disinfectant for cuts and wounds, a teeth whitening agent, a household cleaner, and a hair and skin bleaching agent. It is also used in industrial and medical settings for its oxidizing properties.
5. Can hydrogen peroxide be used as a natural remedy?
There is limited scientific evidence to support the use of hydrogen peroxide as a natural remedy. While it may have some antibacterial properties, it is important to use caution and consult with a healthcare professional before using it for this purpose. It should also never be ingested, as this can be harmful.
  • Chemistry
