Wondering exactly what sine is.
  • Thread starter repugno
  • Tags
    Sine
In summary, sine is a trigonometric function that represents the ratio of the opposite side to the hypotenuse in a right triangle. It can be calculated without a calculator by using algebra and interpolation, and its values for certain angles can be found through geometric constructions or series formulas. The tangent of 90 degrees is undefined, and the values for sine and cosine can be reversed.
repugno
78
I was wondering exactly what sine is. i know that the relationship between sine and the angle is expressed as sinx=opposite/hypotoneuse. But is sine somekind of constant you multiply the angle with to get the O/H ratio? How did the people calculate the ratios without calculaters when they only knew the angles?
Mathematics news on Phys.org
Can't sine theta be thought of as the y value of a point on the unit circle when you rotate it through theta?
cosine is the x value, tan is y/x.
Hence, sine 90 is 1, cos 90 is zero. tan 90 is indeterminant (1/0)
-Gareth
Use algebra to find a lot of values, then interpolate to fill in the gaps.
You should be able to do sin 30 and sin 45 without a calculator. :-p sin 72 can be done with pentagons. (same with cosine) Every multiple of 3 can then be gotten through the addition and subtraction of angles formulae. The half angle formuale can get you even finer... (and the one/third angle formulae, if you know the cubic formula)
One way your calculator could compute them is through their MacLauren series... but I understand they actually use a much cleverer method.
No, tan 90 is undefined -- 90 is not in the domain of the tangent function.
you can learn the values of some standard angles
Code:
degree 0    30       45                      60                   90
 Sin     0    1/2      1/squareroot 2     (root 3)/ 2         1
Cos    reverse the series
Oops! Thanks Hurkyl :redface:
FAQ: Wondering exactly what sine is.
What is sine?
Sine is a mathematical function that relates the angles of a right triangle to its sides. It is often used in trigonometry and has applications in physics, engineering, and other fields.
How is sine calculated?
To calculate sine, you can use a calculator or mathematical tables, or you can use the formula sinθ = opposite/hypotenuse, where θ is the angle of the triangle and the opposite and hypotenuse refer to the sides of the triangle.
What is the range of values for sine?
The values of sine range from -1 to 1. This means that no matter what angle you use, the sine value will always be between -1 and 1.
What are some real-life applications of sine?
Sine has many real-life applications, including calculating the height of buildings, determining the trajectory of projectiles, and measuring the amplitude of sound waves.
Why is sine important in science?
Sine is important in science because it helps us understand the relationships between angles and sides in right triangles. This knowledge is essential in many fields, such as physics, engineering, and astronomy.
