MHB Word problem: Finding The Length Of A Column Of Marching Soldiers
The problem involves calculating the distance of a column of marching soldiers based on the speed of the soldiers and a messenger. The messenger travels to the rear and back, with his speed relative to the soldiers affecting the time taken for each leg of the journey. By setting up equations based on the relationships of distance, speed, and time, the total time can be expressed in hours for accurate calculations. The derived formula shows that the distance from the front to the rear of the column is 5/8 miles. This approach provides a general method for solving similar problems in the future.
NotaMathPerson
An army of soldiers is marching down a road at 5 mi/hr. A messenger on horseback rides from the front to the rear and returns immediately, the total time taken being 10 minutes. Assuming that the messenger rides at the rate of 10mi/hr, determine the distance from the front to the rear.
Can you help me get started with the problem?
Thanks!
Mathematics news on Phys.org
Re: Word problem
We can greatly simplify this problem if we think in terms of the speed of the messenger relative to the marching soldiers. As the messenger rides to the rear of the column, his speed relative to the column is the sum of their actual speeds and when he returns to the front, his relative speed is the difference of their actual speeds. So, we have 3 unknowns: the length of the column (the distance $d$ from the front to the rear), the time $t_1$ spent traveling to the rear and the time $t_2$ spent returning to the front.
Can you now set up 3 equations including these 3 unknowns? Two of the equations will involve the relationship between distance, velocity and time, while the third relates to the relationship between $t_1$, $t_2$ and the total time traveled (which you will want to express in hours since the speeds are given in miles per hour).
Re: Word problem
Hello! I am not sure about this but this is how I will attack the problem based on the relative speed.
Let
x = time taken to travel front-rear
1/6-x = time taken to travel rear-front
Since the distance traveled for two trips are equal
$15x = 5(\frac{1}{6}-x)$
$x = \frac{1}{24}$ hr.
$D = \frac{5}{8}$ mi
Is this correct. If not, please tell me why. Thanks!
Let's work this problem in general terms so that we have a formula we can plug the given data into, so that if presented with s similar problem, we won't have to work essentially the same problem all over again.
So, let's let:
$$v_S$$ = the speed of the soldiers.
$$v_M$$ = the speed of the messenger, where $v_M>v_S$.
Now, we may state:
$$d=\left(v_M+v_S\right)t_1$$
$$d=\left(v_M-v_S\right)t_2$$
$$t_1+t_2=t$$
And so we obtain:
$$\left(v_M+v_S\right)t_1=\left(v_M-v_S\right)\left(t-t_1\right)=\left(v_M-v_S\right)t-\left(v_M-v_S\right)t_1$$
$$\left(v_M+v_S\right)t_1+\left(v_M-v_S\right)t_1=\left(v_M-v_S\right)t$$
$$2v_Mt_1=\left(v_M-v_S\right)t$$
$$t_1=\frac{\left(v_M-v_S\right)t}{2v_M}$$
Hence:
$$d=\left(v_M+v_S\right)\cdot\frac{\left(v_M-v_S\right)t}{2v_M}=\frac{v_M^2-v_S^2}{2v_M}t$$
Plugging in the given data, we find:
$$d=\frac{\left(10^2-5^2\right)\left(\dfrac{\text{mi}}{\text{hr}}\right)^2}{2\cdot10\left(\dfrac{\text{mi}}{\text{hr}}\right)}\cdot\left(10\text{ min}\cdot\frac{1\text{ hr}}{60\text{ min}}\right)=\frac{75}{120}\text{ mi}=\frac{5}{8}\text{ mi}\checkmark$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
