MHB Word problem - linear equation.
The discussion revolves around solving a word problem involving the dimensions of a rectangular swimming pool and its surrounding cement walk. The pool's length is defined as twice its width, and the area of the walk is given as 748 ft². The calculations show that using the variable x for the pool's width leads to dimensions of 28.5 ft by 57 ft. However, there is confusion regarding a discrepancy with a textbook answer of 30 ft by 60 ft, which suggests an area of 784 ft² for the walk. Participants agree that the textbook answer may be incorrect based on the provided area of the walk.
paulmdrdo1
please help me with this problem
please use single variable only.
The length of a rectangular swimming pool is twice its width. The pool is surrounded by a cement walk 4ft wide. If the area of the walk is 748 ft^2, determine the dimensions of the pool.
let x = width of the pool
2x = length of the pool
the dimensions of the pool and cement walk combined
x+8 = width
2x+8 = length
the area of the pool plus the area of the cement walk is equal to the whole area.
$(2x+8)(x+8)=748+2x^2$
$x= 28.5$
the dimensions of the pool is 28.5 ft by 57 ft.
but the answer in my book is 30 ft. by 60 ft. why is that? where did I miss?
regards!
please use one variable only.
Mathematics news on Phys.org
The area of the walk (using your variables) is:
$$2(4x+4(2x+8))=748$$
$$4(6x+16)=748$$
$$6x+16=187$$
$$6x=171$$
$$x=28.5$$
I agree with you.
If the answer is 30 ft x 60 ft then the area of the walk would be 784, not 748. Did you read the question correctly?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
