B Work and energy: conceptual doubt
When sliding a block on a rough surface, the work done by the person equals the work done against friction, resulting in no net energy change for the block, while energy is converted to heat. Similarly, when lifting a block, the work done by the person is equal to the work done against gravity, suggesting no change in the block's energy. However, potential energy is defined for the entire system, including the block and Earth, rather than just the block itself. The confusion arises from the imprecise use of language regarding potential energy, which should be viewed as a system property. Thus, while the block's kinetic energy remains unchanged, the potential energy of the system increases as the block is lifted.
Lalit Tolani
Suppose I am sliding a block very slowly on a rough surface. If the block has traveled ##d## distance then work done by me is ##W_1=\mu mg d## and that by friction is ##W_2=-\mu mg d##.
Now the energy transferred from me to block is ##\mu mgd## and that taken by friction from block is ##\mu mgd ##, The net energy of block remains same but the energy taken by friction evolves as heat and that is equal to my chemical energy consumed, so total energy of ##block + me## system remains constant.
Now If I pull a block of mass ##m## slowly towards up to a height ##h##, then work done by me is ##W_1=mgh## (assuming ##h## is much less than radius of earth) and that by gravity is ##W_2=-mgh##. Therefore ##mgh## goes from me to block and ##mgh## from block to earth, So here also energy of block doesn't change, then why do we say that potential energy of block increases.
I know I am lacking something here, as the total energy of the system would not be conserved if the block's energy doesn't change and my energy decreases.
Please help me in understanding where I am wrong.
The kinetic energy of the block doesn't change, since the net work done on it is zero. Note that there are two ways to talk about the work done by gravity in these sorts of situations: You can explicitly treat gravity as a force, calculating the work it does on the object. Or you can treat it by using gravitational potential energy. But what you cannot do is use both -- that would be counting gravity twice, in effect.
When you get a chance, try reading https://www.feynmanlectures.caltech.edu/I_04.html
Some of the problem here is that the English language is being used imprecisely; strictly speaking we don't have "potential eergy of the block", we have the potential energy of the entire system consisting of the Earth and the block.
Imagine that we've enclosed the whole shebang (earth, block, you, lifting mechanism) in a huge box. Now the total amount of energy inside the box will be conserved as long as we count an increase in potential energy as the block and the Earth are pulled apart.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
