Work and kinetic theorem problem using friction
In summary: But that's a secondary issue.In summary, the problem involves a car of mass 2.1x10^3 kg starting from rest at the top of a driveway that is sloped at an angle of 20 degrees with the horizontal. An average friction force of 4x10^3 N impedes the car's motion, causing it to reach a speed of 3.8 m/s at the bottom of the driveway. Using the kinetic energy theorem and work formula, the length of the driveway can be calculated by equating the work done by friction to the change in kinetic energy. This results in a distance of approximately 5 meters.
Qedpower
A 2.1x10^3 kg car starts from rest at the top of a driveway that is sloped at an angle of 20 degrees with the horizontal. An average friction force of 4x10^3 N impedes the car's motion so that the car's speed at the bottom of the driveway is 3.8 m/s. What is the length of the driveway?
mass of car =2.1x10^3 kg
velocity (final)=3.8 m/s
average friction force= 4x10^3
driveway sloped at 20 degrees
kinetic energy theorem=1/2m(vf)^2-1/2m(vi)^2
work formula=fd(cos θ)
w=ke
If I log the numbers into the kinetic theorem equation
ke=1/2(2.1x10^30)(3.8m/s)^2
If I log the numbers into the work equation
w=4x10^3d(cos 20)
and ke=w
doesn't 4x10^3d(cos 20)=1/2(2.1x10^30)(3.8m/s)^2?
If I simplify this, the distance is 4.03. Is there anything wrong with my equation?
w=ke
w=4x10^3d(cos 20)
and ke=w
Presumably the frictional force will act directly opposing the motion with no relative angle (perhaps a faulty handbrake?). So your "work equation" for the work due to friction is not correct -- there should be no angle involved there.
A bigger problem is that you've left out one source of energy entirely. What's another source of energy when you go downhill?
So have I left out gravity? What do you mean when you said that no angle should be involved?
Yes, you have left out gravity. The friction force has no angle w.r.t. the motion.
I have figured out that mg=average frictionxdistance, is this right?
No, mg is a force (Units of Newtons). Frictional force x distance yields work (units of Joules). Perhaps you meant mgΔh (change in gravitational PE)? Note that only some of the PE gets converted to KE, and some is dissipated due to friction.
Write an energy balance equation for all the energies involved. For a given distance traveled along the driveway, what's the change in gravitational PE? How much energy is lost to friction? Where does the rest go?
I think I've got it. So there are two forces. The downward motion that is helped by gravity and the car's velocity (call it f1) and the average friction (4000). I will be using the formula distance=1/2at^2. I need to find another meaning for the time and acceleration. So f1= mg cos 20 degrees so f1-4000=force without friction (f2). If f1=ma, and a=f1/m,then velocity=f1time/m. This means that t=mv/f1. So if I log it in, the formula is 1/2mv^2/f1. If I plug it in and calculate it, the answer is 5(rounded). The book's answer is 5.1, so I'm not sure if I am correct or not.
Not sure why you'd wand to use (1/2)at2; wouldn't it be more straightforward to employ the work / energy approach?
I don't see how the above can be true. mg cos 20 degrees would be the surface normal force, not a downslope force. And while subtracting the frictional force from the downslope force due to gravity would yield the net downlope force, you never make use of this later.
Your f1 is not the net downslope force acting on the car, so f1=ma will not work.
The only force you should have to deal with is the frictional force so that you can write an expression for the work done by friction over the distance that the car travels (along the driveway). Other than that you have the final kinetic energy of the car and the change in gravitational potential energy due to the car's drop in height over its path. All these ENERGY components are related (think conservation of energy).
By the way, it appears to me that the book's answer of d = 5.1m is not accurate for the given parameters of this problem. I suspect that somewhere along the line someone has revised the "given" values in order to give the problem a makeover, but either forgot to update the answer key to reflect the change or miscalculated the new result themselves; I see the result being closer to 5m than 5.1m.
Related to Work and kinetic theorem problem using friction
1. What is the work and kinetic theorem?
The work and kinetic theorem, also known as the work-energy theorem, states that the net work done on an object is equal to the change in its kinetic energy. This means that the work done by all forces acting on an object will result in either an increase or decrease in its kinetic energy.
2. How is friction involved in the work and kinetic theorem?
Friction is a non-conservative force that opposes motion and can do negative work on an object. In the work and kinetic theorem, the work done by friction is subtracted from the work done by other forces, resulting in a decrease in the object's kinetic energy.
3. Can you give an example of a work and kinetic theorem problem using friction?
One example is a block being pushed along a rough surface with a constant force. The work done by the pushing force will result in an increase in the block's kinetic energy, while the work done by friction will decrease its kinetic energy. The net work done will equal the change in the block's kinetic energy.
4. Is the work and kinetic theorem only applicable to objects moving in a straight line?
No, the work and kinetic theorem can be applied to any type of motion, including circular or rotational motion. In these cases, the work done is calculated using the torque and angular displacement of the object.
5. Is the work and kinetic theorem always true?
The work and kinetic theorem is based on the assumption that all forces acting on an object are conservative, meaning they do not depend on the path taken. In real-world situations, there may be non-conservative forces such as air resistance, which can make the theorem less accurate. However, it is still a useful tool for understanding the relationship between work and kinetic energy in many scenarios.
