Work applied to a spring by my finger muscles
In summary, when you compress the spring with your fingers, you are doing mechanical work on it, which increases its potential energy. However, once it is fully compressed, you are no longer doing work on the spring. Your muscles are still exerting effort to maintain the tension on the spring, but this only results in heat being generated within your body. The compressed spring itself does not generate heat.
NotionCommotion
I take a spring and expend work to compress it with my fingers thereby increasing the potential energy of the spring. After it is at its final compressed state, am I doing work?
Once you stop compressing the spring, you stop doing mechanical work on it.
I agree, but it is a strong spring and all the work I am expending holding it compressed is getting me tired!
Sure! It takes energy for you to maintain that tension. But that's got nothing to do with the spring. You could be replaced by a rock! The rock won't get tired. :smile:
Hey, I am a rock! Well, maybe not...
Expending energy or expending work? My thought is when I hold it, my muscles vibrate resulting in a force over a distance but I don't get the energy back when the spring oscillates as I act as a dampener.
Not sure what you mean by "expending work". But internal to you, your muscles are doing work contracting and relaxing even when your fingers do not move the spring. You require chemical energy in order to maintain that tension on the spring with your fingers.
My muscles are doing work and I am using chemical energy maintaining the tension on the spring, but mechanical work is not being applied to the spring?
Sounds good.
As an extreme example of large amounts of energy being used to generate a static force you should have seen a Concorde doing a ground engine test .
Over 140 000 pounds of thrust being developed by four 593's on a non moving aircraft .
Doc Al said:
Sounds good.
Where is the work performed by my muscles and the chemical energy being transferred to?
Finger pressing against non moving object , Concorde on test , solenoid holding up a load , motor producing stall torque against a load are all example of the same thing - in loose definition they are machines of zero efficiency .
In each case all energy being used to produce a force against a non moving object is dissipated as heat .
(2)
Consider three possible conditions :
Non moving load .
Accelerating load .
Load moving at constant velocity .
Same 'engine' has different values of efficiency for energy transfer in each condition .
Zero efficiency is the default case of load not moving .
Likes billy_joule
All these goings on are within your body. It all ends up as increased internal energy ("heat").
Exactly.
Sorry for being dense.
After compressing the spring with my fingers, I wedge my fingers between a crack in a big rock. I do this for many days until I die and decompose and obviously am no longer utilizing any chemical energy, yet still the spring is compressed. My index finger and thumb bones both have an equal and opposite force on both sides, and so does both sides of the crack in the rock.
Is something now creating heat?
No.
There's nothing intrinsic to the compressed spring that "creates heat". Recall that you could compress the spring with a rock and there will be no additional work done or energy transferred once the spring is fully compressed. It's only when you (your biochemical system) are actively creating tension or muscular effort that you "create heat".
Related to Work applied to a spring by my finger muscles
1. What is the concept of work applied to a spring by my finger muscles?
The concept of work applied to a spring by finger muscles refers to the force exerted by the muscles in the fingers to compress or expand a spring. This work is measured in joules and is dependent on the force applied and the distance the spring is compressed or expanded.
2. How does work applied to a spring by my finger muscles affect the spring?
The work applied to a spring by finger muscles causes the spring to compress or expand, depending on the direction of the applied force. This work is stored in the spring as potential energy, which can then be released to do work when the spring returns to its original state.
3. What factors affect the amount of work applied to a spring by my finger muscles?
The amount of work applied to a spring by finger muscles is affected by the force applied and the distance the spring is compressed or expanded. The stiffer the spring, the more work is required to compress or expand it, and the more force applied, the more work is done.
4. How is the work applied to a spring by my finger muscles calculated?
The work applied to a spring by finger muscles can be calculated using the formula W = F * d, where W is work in joules, F is the force applied in newtons, and d is the distance the spring is compressed or expanded in meters.
5. Can work applied to a spring by my finger muscles be converted into other forms of energy?
Yes, the work applied to a spring by finger muscles can be converted into other forms of energy, such as kinetic energy when the spring is released and expands or compresses an object, or thermal energy when the spring experiences friction during compression or expansion.
  • Mechanical Engineering
  • Classical Physics
  • Other Physics Topics
