Work done against friction for a car with 125 KJ KE.
In summary: What are the choices?1. Work done against friction2. Energy lost due to kinetic energy3. Distance traveledIn summary, the 1200kg car as kinetic energy 125kJ at the bottom of a 20 degree slope. It rises to a height of 10m. Calculate work done against friction.
Molly1235
77
"A 1200kg car as kinetic energy 125kJ at the bottom of a 20 degree slope. It rises to a height of 10m. Calculate work done against friction."
Relevant equations:
Work = force x distance in direction of that force
Work = KE = 1/2 x m x v^2
I'm not really sure where to start...tried several things but haven't got anywhere.
For example:
Work done = KE
125000J = 1/2 x 1200 x v^2
V^2 = 125000/600 = 208.3
V = 14.4 m/s
Or
GPE at top of slope = mgh
1200 x 9.81 x 10 = 117,720
Energy lost = 125000 - 117720 = 7280 J
But neither of these answer the question.
Also tried
Distance traveled = 10/sin20 = 29.24m
So f = 125000/29.24 = 4274.9J buy apparently that's wrong.
Someone please help? :-)
This is the one you want.
If that's not right: Are you sure it says "rises to a height " of 10m? Maybe they meant that it travels up the ramp a distance of 10 m?
I tried it that way as well and none of the answers match up (it's multiple choice). Hm, perhaps I copied the answers/some of the question down wrong!
So just to confirm, would the energy lost be the same as the work done against friction?
Yes, assuming friction is the only source of energy "loss".
Related to Work done against friction for a car with 125 KJ KE.
1. What is work done against friction?
Work done against friction is the amount of energy expended to overcome the force of friction between two surfaces in motion. In the case of a car with 125 KJ of kinetic energy, work done against friction would involve using 125 KJ of energy to counteract the friction between the car's tires and the road.
2. How is work done against friction calculated?
Work done against friction can be calculated by multiplying the force of friction by the distance traveled. In the case of a car with 125 KJ of KE, the force of friction would need to be measured and multiplied by the distance the car travels to determine the work done against friction.
3. Why is work done against friction important?
Work done against friction is important because it represents the energy lost due to the resistance of motion between two surfaces. This energy is converted into heat, which can affect the efficiency and performance of a system, such as a car.
4. How does the amount of kinetic energy affect the work done against friction?
The amount of kinetic energy directly affects the work done against friction. The higher the kinetic energy, the more work that needs to be done to overcome friction and maintain the motion of the object. In the case of a car with 125 KJ of KE, more energy would be needed to overcome friction compared to a car with lower KE.
5. Can work done against friction be reduced?
Yes, work done against friction can be reduced by using lubricants, reducing the weight or contact area of the objects in motion, or by designing systems with less friction. In the case of a car, regular maintenance and using high-quality lubricants can help reduce the amount of work needed to overcome friction and improve its overall performance.
