Work Done and Acceleration (Mistaken Answers?)
In the discussion regarding work done and acceleration, a participant expressed confusion over answers related to acceleration and power in physics problems. They initially answered that there is acceleration down towards Earth, but the solution stated otherwise, leading to uncertainty. It was confirmed that the participant's answers were correct, but concerns were raised about the reliability of test bank questions. The conversation highlighted the misconception that zero velocity implies zero acceleration, emphasizing that acceleration remains consistent across inertial frames. The discussion underscores the importance of accurate physics education and the potential issues with existing test materials.
amandela
Q1) A ball is thrown and follows a parabolic path. Air friction is negligible. Point Q is the highest point on the path. What is the direction of the acceleration there?
Q2) A weightlifter lifts a mass m at constant speed to a height h in time t. How much work is done by the weightlifter?
Wnet = ΔKE + ΔPE + Wnc
So for Q1, I answered down (towards Earth) but the solution says there is no acceleration there.
For Q2, I answered mgh, but the solution says it's mgh/t, which is power, right?
I just want to make sure I'm not super confused.
Thank you.
You are correct in both cases. Where are you getting the other answers from?
Agreed, except that if the weight is lifted from rest at speed h/t then it reaches h with KE ##\frac 12mh^2/t^2##.
It says at constant speed.
Thank you. They're from a test bank for the AP mechanics exam.
There seems to be a growing problem with dodgy questions and/or dodgy answers. That someone teaching physics might think the acceleration is zero when velocity is zero ought to shock me, but doesn't surprise me.
Note that for any motion you can always change your inertial frame of reference so that an object is instantaneously at rest. But, acceleration is the same across all inertial reference frames. Which is why Newton's laws deal with force and acceleration and not velocity.
Likes Lnewqban and amandela
