Work done by a spring on a block when released from 14cm?
In summary, the conversation discusses how much work a spring does on a block when it is moved from xi=+6.0 cm to various positions. The formula Fs=-kd is used, but there was an error in converting units from cm to m. Once the units are corrected, the correct answer is found.
rockchalk1312
38
A block is attached to a spring which is attached to a stationary wall. When the block is pulled out to x = +5.0 cm, we must apply a force of magnitude 370 N to hold it there. We pull the block to x = 14.0 cm and then release it. How much work does the spring do on the block when the block moves from xi=+6.0 cm to (a)x= +3.0 cm, (b)x=-3.0 cm, (c)x=-6.0 cm, and (d)x=-10.0 cm?
Fs=-kd
Ws=1/2kxi2-1/2kxf2
Tried to find k by doing 370=-k(5)=-74
but then plugging this into:
W=1/2kxi^2-1/2kxf^2
W=1/2k(6^2)-1/2k(3^2)
W=18k-4.5k
W=13.5k
W=(13.5)(74)=999
This was definitely not the right answer. How do you go about finding k, or do you have to do something differently since the block was originally released from 14cm? Thank you!
Make sure all your numbers are in the same system of units.
Fs=-kd
Ws=1/2kxi2-1/2kxf2
W=1/2kxi^2-1/2kxf^2
W=18k-4.5k
W=13.5k
W=(13.5)(74)=999
Be careful with units. The distance is 5 cm. If the problem is expecting an answer in Nm, then you must make sure everything is in SI units, which means converting distances to m. Of course, if you did the rest of it right, then your answer should be in N*cm, which means it should only have been off by some factors of ten. :wink:
I was off by two factors of ten. Thank you very much!
I would approach this problem by first clarifying some details. Is the block being pulled out to x = +5.0 cm and then released, or is it being pulled out to x = 14.0 cm and then released? This will affect the initial position of the block and the corresponding spring force.
Assuming the block is being pulled out to x = +14.0 cm and then released, we can calculate the spring constant (k) using the given information. The spring force is given by F = kx, where x is the displacement from the equilibrium position. At x = +5.0 cm, the force needed to hold the block in place is 370 N, so we can write:
370 N = k(5.0 cm)
k = 74 N/cm
Now, let's calculate the work done by the spring as the block moves from xi = +6.0 cm to different positions:
(a) x = +3.0 cm:
The block moves 3.0 cm closer to the equilibrium position, so the displacement is -3.0 cm. Using the formula W = 1/2 k xi^2 - 1/2 k xf^2, we get:
W = 1/2 (74 N/cm) (6.0 cm)^2 - 1/2 (74 N/cm) (3.0 cm)^2
W = 666 J
(b) x = -3.0 cm:
The block moves 3.0 cm past the equilibrium position, so the displacement is +3.0 cm. Using the same formula, we get:
W = 1/2 (74 N/cm) (6.0 cm)^2 - 1/2 (74 N/cm) (-3.0 cm)^2
W = 666 J
(c) x = -6.0 cm:
The block moves 6.0 cm past the equilibrium position, so the displacement is +6.0 cm. Using the same formula, we get:
W = 1/2 (74 N/cm) (6.0 cm)^2 - 1/2 (74 N/cm) (-6.0 cm)^2
W = 1488 J
(d) x = -10.0 cm:
The block moves 10.0 cm past the equilibrium position, so the displacement is +10.0 cm. Using the same
FAQ: Work done by a spring on a block when released from 14cm?
What is work done by a spring on a block?
The work done by a spring on a block is the amount of energy transferred to the block when the spring is released. It is a measure of the change in the kinetic energy of the block as it moves.
How is work done by a spring on a block calculated?
The work done by a spring on a block can be calculated using the formula W = (1/2)kx^2, where W is the work done, k is the spring constant, and x is the displacement of the block from its equilibrium position. In this case, x would be 14cm.
What is the unit of measurement for work done by a spring on a block?
The unit of measurement for work done by a spring on a block is joules (J). This is the same unit used to measure energy.
How does the work done by a spring on a block change with different release heights?
The work done by a spring on a block increases with higher release heights. This is because the release height is directly proportional to the displacement of the block, and according to the work formula, a larger displacement results in a larger amount of work done.
Does the mass of the block affect the work done by a spring on it?
Yes, the mass of the block does affect the work done by a spring on it. The work done is directly proportional to the mass of the block. This means that a heavier block will require more work to be done by the spring compared to a lighter block with the same release height and displacement.
