Work done by electromagnetic force
In summary: So if I wanted to represent this displacement as a vector, I would write: (3,2)Which is just a vector pointing in the direction of (3,2).
scarlets99
1.Calculate the work done by the force F=i cos(pix/4) + j y2 along the path y=x2 in the x-y plane from (0,0) to (2,4).
2.Is the force F conservative? Explain.
Work = Integration between a and b of F.dl
1. I know it's a line integral between the 2 points, I'm just unsure of how to do it.
2.If W=0 then it is conservative
You have to find the dot product of the vector F and the vector dl and then integrate the result over the curve.
Nope. Think about this, does it make sense that a conservative force never does work between any two points? (Gravity and the electrostatic force are both conservative).
You're probably thinking of a result that the line integral of a conservative vector field around a closed path is 0. But in this case it's not a closed path, since the starting and ending points are not the same.
It's a conservative force if the work done in moving between any two points is independent of the path taken between them. In other words, all line integrals between point A and B, regardless of path, give you the same result. So the work done depends only on the two endpoints (you can probably see how the thing about closed paths follows from this property).
Another way to think about it is that a conservative vector field can always be expressed as the gradient of some scalar function usually called a "potential function" (which in the case of conservative forces actually represents the potential energy). So you can figure out the work done between any two points just by looking at the difference in potential between them. It doesn't matter how you got from one to the other.
Thank you cepheid.
What is the value of dl?
scarlets99 said:
Thank you cepheid.
Well, I think that moving a small (infinitesimal) displacement dl along the curve means moving a small displacement in the x-direction + a small displacement in the y-direction. Does that help? (How would you express what I just said in vector form?)
dxdy?
So the integral between 0 and 2, and 0 and 4 F.dxdy
scarlets99 said:
dxdy?
NO. dxdy has dimensions of area (m2), so you know that it can't possibly be a displacement vector.
I'm not sure why you multiplied. Take a look again at what I said :
Another hint: it might help to think about a simpler example first: if I move from the origin 3 m in the x-direction and then 2 m in the y-direction, how would I express that displacement in Cartesian vector form? Now, instead of 3 m and 2 m, generalize that to infinitesimal straight-line displacements dx and dy (infinitesimal since you're actually moving along a curve and just approximating it as a sequence of straight-line moves, and then taking the limit as the size of those straight-line moves goes to zero).
Related to Work done by electromagnetic force
What is work done by electromagnetic force?
Work done by electromagnetic force refers to the amount of energy expended when an object is moved through a distance due to the influence of an electromagnetic field.
How is work done by electromagnetic force calculated?
The work done by electromagnetic force can be calculated by multiplying the magnitude of the force by the distance the object is moved in the direction of the force.
What are some examples of work done by electromagnetic force?
Examples of work done by electromagnetic force include lifting an object with an electromagnet, pushing a charged particle through an electric field, and moving a conductor through a magnetic field.
Is work done by electromagnetic force always positive?
No, work done by electromagnetic force can be positive, negative, or zero. It depends on the direction of the force and the direction of the displacement of the object.
How does work done by electromagnetic force relate to electrical and magnetic energy?
Work done by electromagnetic force is directly related to the electrical and magnetic energy present in a system. The amount of work done is equal to the change in energy of the system.
