sophiecentaur said:
I know they love to tell you at School that electricity is all about electrons moving but the problem is, they move very slowly and the explanation is, ifaiac, a bit of a cop out. It is actually quite difficult to justify those last two posts in detail when you are dealing with AC. The same electrons are moving backwards and forwards inside the resistor for hours on end and another set of them are moving in and staying in the cables. None of them do what those two posts are implying. i.e. they don't 'have energy' then 'give it up'.
You should really stick to 'Charge' as your conceptual carrier of energy. OK it may be a bit abstract but it avoids falling over yourself and coming to dodgy conclusions.
I think potential is a bit arbitrary anyway. So of course you could assign it with AC current, it would just be constantly changing and likely a bad way to think about it. The main point to be made is that the source driving current performs work and it can only do so because of the resistance within the circuit performing "negative work," if you will. That is, no net work is required to move charges from here to there if there is no intermediate resistances.
tonyjk said:
i think across the resistance there's drop of potential it means that the potential energy of the electrons is converted to heat? despite that the electron moves from a lower potential to a higher potential right?
For the sake of defining potential for an electron, no, it does not move from a lower to higher potential. That goes against the purpose of defining potential. In order for an electron to do positive work (and thus produce heat) it must lose potential energy.
Maybe you are still thinking of electric fields and are getting confused as to what an electric field means for an electron? An electric field is defined such that its direction points away from positive charges and toward negative charges. In consequence, it also describes the direction a
positive charged particle will experience a force in. That is, an ideal positive charged particle will have field lines directed radially outward and placing another
positive charged particle near it - you will find that the force it experiences is also radially outward - just as the field lines indicate. Place an electron in this vicinity however, and you get the opposite result.
In summary, a positive charged particle gains potential energy when an external force does positive work on the particle. That is, when this external force moves the particle in the opposite direction of the field. For a negative charged particle (electron) potential energy is gained when an external force does positive work on it also. However, in order to do positive work, the negative charged particle must be moved
in the direction of the electric field. Why? Because the positive charged particle creating the radial outward fields actually attracts the electron rather than repelling it as would be so with another positive charge.
So
ΔU = W = -We = -∫F . dD = -∫qE . dD
{ΔU = change in potential energy, W = external work, We = work done by electric field (or source creating electric field, if you will), F = force on charge by field, q = charge of particle including sign, E = electric field created by source, D = displacement}
Being as simple as I can, when an electron goes over a potential difference of ΔV (positive change,) its potential energy change is -qΔV where I have explicitly place its negative charge sign. So it's potential energy change is explicitly negative in sign.
