How Is Work Done by Friction Calculated in Physics Problems?
In summary, the conversation discussed a flight attendant pulling a flight bag at a constant velocity over a distance of 323 m. The force she exerts is 46.0 N at an angle of 61.3° above the horizontal. The work done by the flight attendant on the bag was found to be 7135.16 J, and the work done by the force of friction was -7135.16 J. The coefficient of kinetic friction between the bag and the floor was also discussed, with the equation for the force of friction being mentioned as well. The next step to solving for the coefficient would involve finding the friction force and normal force.
kiwikahuna
61
A flight attendant pulls her 60.4 flight bag
a distance of 323 m along a level airport floor
at a constant velocity. The force she exerts is
46.0 N at an angle of 61.3° above the horizon-
tal.
a) Find the work she does on the flight bag.
Answer in units of J.
b) Find the work done by the force of friction
on the flight bag. Answer in units of J.
c) Find the coefficient of kinetic friction be-
tween the flight bag and the floor.
force of friction = normal force X coeffiecent of kinetic friction
I have found that the work she does on the flight bag is 7135.16 J and the work done by the force of friction is -7135.16 J.
I can't seem to comprehend how to solve for the coefficient. If you can lend a hand in the right direction, I would appreciate it very much!
That's what you need. Figure out the friction force (you must have figured that one out already) and the normal force.
Hello,
I can provide some insights on the concept of work done by friction in this scenario. Friction is a force that opposes the motion of objects in contact with each other. In this case, the flight attendant is exerting a force of 46.0 N on her flight bag at an angle of 61.3° above the horizontal. This force is balanced by the force of friction, which is acting in the opposite direction. Since the flight bag is moving at a constant velocity, the net force acting on it is zero, and therefore the work done by the net force is also zero.
To find the coefficient of kinetic friction, we can use the equation you mentioned, which is force of friction = normal force x coefficient of kinetic friction. In this case, the normal force is equal to the weight of the flight bag, which can be calculated as mass x gravity. We can also use the relationship between work and force, which is work = force x displacement x cosθ, where θ is the angle between the force and displacement. Since the work done by the net force is zero, we can set the work done by the force of friction equal to the work done by the flight attendant, which is 7135.16 J. Solving for the coefficient of kinetic friction, we get a value of 0.117.
I hope this helps in your understanding of work done by friction and how to solve for the coefficient of kinetic friction. Keep up the good work!
FAQ: How Is Work Done by Friction Calculated in Physics Problems?
What is work done by friction?
Work done by friction refers to the energy that is dissipated or transformed into heat when an object moves against a surface due to the force of friction.
How is work done by friction calculated?
The work done by friction can be calculated by multiplying the force of friction by the distance over which the object moves. This is represented by the equation W = Fd, where W is work, F is force, and d is distance.
What factors affect the amount of work done by friction?
The amount of work done by friction is affected by the type of surface, the force applied, and the distance over which the object moves. Additionally, the coefficient of friction, which is a measure of the roughness or smoothness of the surfaces in contact, also plays a role.
Is work done by friction always negative?
No, work done by friction can be either positive or negative depending on the direction of motion. When the force of friction acts in the same direction as the motion of the object, the work done is positive. But if the force of friction acts in the opposite direction to the motion, the work done is negative.
How does work done by friction affect the motion of an object?
The work done by friction reduces the kinetic energy of an object, causing it to slow down. This means that friction plays a crucial role in controlling the speed and motion of an object.
