Work done by frition on a crate
In summary, the work done by friction on the crate is -500 Joules. This is because friction acts in the opposite direction of the displacement of the crate, causing its kinetic energy to decrease. Therefore, the work done by friction is equal to the final kinetic energy minus the initial kinetic energy, which results in a negative value. The formula to remember is ∆(kinetic energy) = total work done, which in this case is mgh - Fd.
cbeeson23
A 70 kg crate starting at rest slides down a rough ramp 4.0 meters long, inclined at 30 degrees above horizontal. At the bottom, it is moving at 5.0 m/s. what was the work done by friction on the crate?
Answers=
A. -500 Joules
B. 500 Joules
C. 460 Joules
D. -460 Joules
E. 0.0 Joules
I got this answer wrong and i was wondering why... so here is my work. i got the height to be 2meters by using sin 30
Mgh - Wf = 1/2MV^2
70 * 9.81 * 2 - wf = .5 * 70 * 5.0^2
875 - wf = 1373.4
wf =1373.4-875
wf = 500 joules
so i got positive 500 joules. can anybody tell me what the answer truly is and what i did wrong?? thank you alot!
Welcome to PF!
Hi cbeeson23! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Work done = force "dot" displacement …
the friction is up, but the displacement is down. :wink:
so the answer then would be -500 joules?
should my equation have been mgh = 1/2mv - work
Or are you saying that the work done is actually 500 joules, but since friction is what goes up the ramp the work done by friction is actually - 500 joules?
can any1 explain this answer to me a little better
Frictional force acts in the opposite direction of the displacement of the crate.
When the work is done on a body, its kinetic energy increases.
When the work is done by a body, its kinetic energy decreases.
When there is no friction, mgh = 1/2*mv^2
Here mgh > 1/2*mv^2
So due to friction kinetic energy of the crate decreases.
Hence work done by the friction = final energy - initial energy.
Hi cbeeson23! :smile:
(just got up :zzz: … )
If you're confused, then don't treat potential energy as part of the energy, treat it as part of the work done (PE is just another name for minus work done in a conservative field, such as gravity).
which in this case is mgh - Fd :smile:
FAQ: Work done by frition on a crate
1. What is friction and how does it affect work done on a crate?
Friction is a force that opposes motion between two surfaces in contact. When a crate is moved across a surface, friction acts in the opposite direction of the crate's motion, making it harder to move and increasing the work required to move it.
2. How is the amount of work done by friction on a crate calculated?
The work done by friction on a crate is equal to the force of friction multiplied by the distance the crate is moved. This can be represented by the equation W = Fd, where W is work, F is force, and d is distance.
3. Does the type of surface the crate is moved across affect the work done by friction?
Yes, the type of surface can greatly affect the work done by friction on a crate. Rougher surfaces typically have higher coefficients of friction, meaning more force is required to move the crate and more work is done by friction.
4. How can the work done by friction on a crate be reduced?
The work done by friction on a crate can be reduced by using lubricants or smoother surfaces. These can reduce the coefficient of friction, making it easier to move the crate and requiring less work to be done by friction.
5. Is the work done by friction always negative?
Not necessarily. The work done by friction on a crate can be positive if the crate is moving in the same direction as the force of friction. This can occur, for example, if the crate is being pushed downhill and friction helps slow it down.
