Work Done by Gravity and Tension in a Pulley System
In summary, the conversation discusses the work done by gravity and tension on two blocks connected by a rope across a pulley. Block A has a mass of 4 kg and is on the ground, while block B has a mass of 12 kg and is 2 meters above the ground. When released, block B hits the ground and block A rises to 2 meters with a final speed of 4.43 m/s. The equations used to find the work done by gravity and tension are total work = change in kinetic energy and work done by gravity = mg(Hf - H0). The net work done by tension on both blocks is zero, but when analyzed separately, the tension does non-zero work on each block.
solarcat
Two blocks are attached to a rope across a pulley. Block A is on the ground and has a mass of 4 kg. Block B is 2 meters above the ground and has a mass of 12 kg. When the blocks are released, block B hits the floor and block A rises to 2 meters; each block has a final speed of 4.43 m/s. Find the work done by gravity and tension for each block.
Total Work = Change in kinetic energy = Work done by gravity + work done by tension
Work done by gravity = mg(Hf - H0)
Block A
KE 0 = 0
KEf = (1/2) (4 kg) ( 4.43 m/s)2 = 39.2 J
Total work = KEf - KE0 = 39.2 J
Work done by gravity = 4 kg * 9.8 m/s2 * 2m = 78.4 J
Total work = work done by gravity + work done by tension
39.2 = 78.4 + Wt
Wt = -39.2 J
Similarly, Wg for block B is -235.2 J and Wt = 352.9 J
But shouldn't the work done by tension be 0 because the work done by tension on B is equal to the work done by tension on A?
39.2 = 78.4 + Wt
Wt = -39.2 J
Careful with signs. The work done by gravity on block A is negative, since gravity acts down while the block rises. Similarly, the work done by tension on that block must be positive.
The net work done by tension on both masses will be zero, yes. But if you analyze each block separately, the tension does non-zero work on each.
Be careful with signs.
First, decide whether positive is up or down, then use signs for acceleration and displacement accordingly.
You could solve:
$$M_bg-T=M_ba...1$$ and
$$ T-M_ag=M_aa...2$$
After which work done by tension on B is just -TΔx and on A +TΔx summing to zero as you expect.
Related to Work Done by Gravity and Tension in a Pulley System
1. What is work done by gravity/tension?
The work done by gravity or tension is the amount of energy expended when an object is moved against the force of gravity or tension. This work is calculated by multiplying the force applied by the distance the object is moved.
2. How is work done by gravity/tension calculated?
The work done by gravity or tension is calculated using the formula W = F x d, where W is work, F is the force applied, and d is the distance the object is moved.
3. What is the difference between work done by gravity and work done by tension?
The main difference between work done by gravity and work done by tension is the type of force being applied. Gravity is a downward force exerted by the Earth, while tension is a pulling force exerted by a string or rope. Additionally, work done by tension can be positive or negative depending on the direction of movement, while work done by gravity is always negative (since gravity works against the motion).
4. How does the angle of application affect work done by gravity/tension?
The angle of application does not affect the work done by gravity, as gravity always acts vertically downwards. However, for tension, the angle of application can affect the amount of work done. The work done by tension is greatest when the angle is 180 degrees (directly opposite to the direction of movement) and decreases as the angle decreases.
5. What are some real-life examples of work done by gravity/tension?
Examples of work done by gravity include lifting an object off the ground, climbing stairs, or jumping. Examples of work done by tension include pulling a sled, lifting weights, or using a pulley system to lift objects.
