OOps yeah it is, ill change it. D: if the displacement in the same direction as force then there is work, so going down is 100% positive.Doc Al said:What's the definition of the work done by a force? What determines whether that work is positive or negative?
(Is this thread mistitled?)
Careful. Work is done even if they are in opposite directions. But the sign is different.axer said:if the displacement in the same direction as force then there is work
RIght, because force and displacement are in the same direction.axer said:so going down is 100% positive.
It shouldn't be. :)axer said:But going up is tricky.
Done.axer said:EDIT: i can't edit it.
so the work going up is negative, since gravity pulls down and displacement is going up.?Doc Al said:Careful. Work is done even if they are in opposite directions. But the sign is different.RIght, because force and displacement are in the same direction.It shouldn't be. :)Done.
Exactly.axer said:so the work going up is negative, since gravity pulls down and displacement is going up.?
thanks, you're a life saver.Doc Al said:Exactly.
Work = Force x Displacement. No matter what sign convention you use, when the force and displacement are in the same direction, work is positive; when opposite, work is negative. (Try it and see.)
Work done by gravity is the amount of energy required to move an object against the force of gravity. This can be calculated by multiplying the force of gravity (usually 9.8 m/s^2) by the distance the object is moved.
No, work done by gravity can be either positive or negative. It depends on the direction of the movement of the object. If the object moves in the same direction as the force of gravity, the work done is positive. If the object moves in the opposite direction, the work done is negative.
A positive work done by gravity means that the object is moving in the same direction as the force of gravity. This typically occurs when an object is falling towards the ground.
A negative work done by gravity means that the object is moving in the opposite direction of the force of gravity. This can happen when an object is being lifted or thrown upwards.
The mass of an object does not affect the work done by gravity. The work done by gravity depends on the distance an object is moved and the force of gravity, but not the mass of the object.
