Work done by kinetic frictional force
In summary, the problem involves a 356 N force pulling a 90.2-kg refrigerator across a horizontal surface at an angle of 25.6 ° above the surface. The coefficient of kinetic friction is 0.258 and the refrigerator moves a distance of 9.55 m. The work done by the pulling force is 3066.050223J, and the work done by the kinetic frictional force is -1798.985720775539J. The correct method for finding the work done by the frictional force is by considering the normal reaction force and the horizontal component of the pulling force.
Jacque77
Answer
Chapter 6, Problem 73 Cutnell & Johnson 7th edition
A 356 N force is pulling an 90.2-kg refrigerator across a horizontal surface. The force acts at an angle of 25.6 ° above the surface. The coefficient of kinetic friction is 0.258, and the refrigerator moves a distance of 9.55 m. Find (a) the work done by the pulling force, and (b) the work done by the kinetic frictional force.
(a)
Number
3066.050223272106 Units J
(b)
Number
-1798.985720775539 Units J
First : sig figs are turned off in my course. The listed answers have to be within 2%. Please no lectures about sig fig. In any other course I obey the rules. ;)
Incorrect.
(a) Number 3066.050223 Units J (is correct)
(b) Number -1964.181362 Units J (is incorrect)
The 3066.050223J work for the part (a) is correct. Part (b) is the incorrect part I need help with.
Wf = Ff*d*cos 25.6 where Ff = μ*m*g
so 0.258*90.2*-9.8*9.55*cos 180 = -2178 J
0.258*90.2*-9.8*9.55*cos 25.6 = -1964.181362
I've exceeded the 3 tries and can see the correct answer of -1798.985720775539, but have no idea how that was arrived at. The hint given with the problem says to set ΣFy = 0 before considering the Wf . ??
What am I doing wrong?
W= F*D cos 25.6
FN = mg = weight of the refrigerator
W done by pulling force
W= F*D cos 25.6
W= 356N*9.55m*cos 25.6 = 3066.050223J
.258*90.2*9.8*9.55*cos 180 = -2178J
0.258*90.2*-9.8*9.55*cos 25.6 = -1964.181362 is incorrect. The correct answer is -1798.985720775539. ?How?
Is there a y componet to the 356 N force as well as an x componet?
the 90.2 cos 25.6 considers the y. The 9.55 m moved is the x
This is incorrect:
(1) When using W = F*d*cos(theta), theta is the angle between the force and the displacement. In this case the force (friction) is horizontal and so is the displacement.
(2) Ff = μ*N, but N is not simply mg. You need to consider the effect of the vertical component of the applied force.
The normal reaction force exerted on the refrigerator,
FN = mg - F sin 25.6 = 90.2x9.8 - 356x0.432
= 884 - 154 = 730 N.
Force of friction,
f = μ FN = 0.258 x 730
=188.3 N
along the horizontal surface, but opposite to displacement.
Work done by the frictional force,
Wf = f.S = - f.S cos 180 = -f.S
= - 188.3 x9.55 = - 1798. J
Now you've got it.
Related to Work done by kinetic frictional force
1. What is work done by kinetic frictional force?
The work done by kinetic frictional force is the energy expended in overcoming the resistance of surfaces in relative motion. It is a type of force that opposes the motion of an object and is dependent on the coefficient of kinetic friction and the normal force.
2. How is the work done by kinetic frictional force calculated?
The work done by kinetic frictional force can be calculated by multiplying the force of kinetic friction by the distance traveled in the direction opposite to the motion. This can be represented by the equation W = Fk*d.
3. What factors affect the work done by kinetic frictional force?
The work done by kinetic frictional force is affected by the coefficient of kinetic friction, which is dependent on the types of surfaces in contact and their roughness. It is also affected by the normal force, which is the force exerted by the surface on the object.
4. Can the work done by kinetic frictional force be positive or negative?
The work done by kinetic frictional force can be both positive and negative. It is considered positive when the object is moving in the direction opposite to the force of friction, and negative when the object is moving in the same direction as the force of friction.
5. Why is the work done by kinetic frictional force often considered to be wasteful?
The work done by kinetic frictional force is often considered to be wasteful because it converts useful energy into heat, which cannot be used to do work. This is why friction is often seen as an obstacle in machines and other mechanical systems.
