Work done by quadratic air resistance.
In summary, a baseball with a mass of 0.145kg and a radius of 0.0366m is dropped from a 381m high tower. The attempt at a solution involved using the equation Work = integral (from 0 to 381) c(2) (terminal velocity)^3 * (tanh(t/(characteristic time)))^3 with respect to time, but resulted in incorrect numbers. Another perspective is that the object has less energy when it hits the ground due to air resistance, resulting in a difference in work done by the air resistance force.
GS416492
A baseball of mass 0.145kg and radius 0.0366m is dropped from a tower 381m high.
Work=integral(from 0 to 381): c(2) (terminal velocity)^3*(tanh(t/(characteristic time)))^3 with respect to time.
Gets me really strange (incorrect) numbers
You could also look at it this way: the object would have a certain energy when it hits the ground if it was freefalling with no air resistance. It has less energy when it hits the ground if it falls with the air resistance. The difference is due to the work of the air resistance force.
every time I try to solve it.
I would suggest using the formula for work done by air resistance, which is W = Fd = 1/2 * p * Cd * A * v^2 * d, where p is the density of air, Cd is the drag coefficient, A is the cross-sectional area of the object, v is the velocity, and d is the distance traveled. This formula takes into account the quadratic relationship between air resistance and velocity, and will give you a more accurate estimate of the work done on the baseball as it falls from the tower. It is also important to note that the terminal velocity of the baseball will also change as it falls, so you may need to use the appropriate value for v in the equation at each point in time.
FAQ: Work done by quadratic air resistance.
What is "Work done by quadratic air resistance"?
"Work done by quadratic air resistance" refers to the energy expended in overcoming the resistance of air on an object moving through it. This type of resistance is described by a quadratic function, meaning that it increases with the square of the object's velocity.
How is the amount of work done by quadratic air resistance calculated?
The work done by quadratic air resistance can be calculated using the formula W = (1/2) * Cd * rho * A * v^2 * d, where Cd is the drag coefficient, rho is the density of air, A is the cross-sectional area of the object, v is the velocity, and d is the distance traveled.
What factors affect the amount of work done by quadratic air resistance?
The amount of work done by quadratic air resistance is affected by several factors, including the velocity of the object, the density of air, the object's cross-sectional area, and the distance traveled. Additionally, the drag coefficient may vary depending on the shape and surface roughness of the object.
Why is it important to consider work done by quadratic air resistance?
Considering the work done by quadratic air resistance is important in many fields, such as aerodynamics and sports. It helps in understanding the amount of energy required to overcome air resistance and can be used to optimize the design of objects to minimize this type of resistance.
How does the work done by quadratic air resistance compare to other types of resistance?
The work done by quadratic air resistance is just one type of resistance that objects may encounter. Other types of resistance, such as friction or rolling resistance, may also need to be considered. The amount of work done by quadratic air resistance may be greater or less than these other types of resistance, depending on the specific circumstances.
10K
