Work done by the electric field
In summary, electric fields from charged objects work on other charges and lose energy. The lost energy comes from the distances between the charges changing.
JimBeans
Apologies in advance if this question seems trivial, I seem to have missed something conceptually and would like some clarification.
If an electric field from a point charge does work on another charge and thereby loses energy, where does the lost energy come from?
It is my understanding that the energy in the electric field is directly proportional to the magnitude of the point charge from which it comes. Does this mean when the electric field does work, the point charge effectively loses charge?
To me that seems to make no sense, so if anyone could clarify I would appreciate it.
Thanks for your time.
Hi. Electric field working on a charge is coming not from that charge but from other charges. Via electric field the charge and other charges interact and energy and mometum transfer occurs.
Charge does not change but distances between charges tend to change to lose or store energy in the fields.
Likes JimBeans
Welcome to Physics Forums!
A charged object does not lose charge simply by doing work (i.e. attracting or repelling) another charged object, since total charge must be conserved. You're intuition is correct that losing charge makes no sense.
I'll give an example shortly. There are two things to keep in mind: (1) the energy stored in "the electric field" is stored in the combined field of all charged objects, not in the field of just one object or the other. (2) the energy density due to the field is proportional to the square of the electric field magnitude.
So, imagine two positively charged objects, relatively close to each other and initially at rest. They repel each other and, as time goes on, they get further apart. Work is done on each object by the field of the other, and both objects gain kinetic energy due to that work.
Now we can ask, how does the field, and the energy stored in the field, change as the charged objects separate? In the vicinity of the charges, the field gets weaker as the charges move farther apart. With the field energy depending on the square of the field magnitude, we find -- when we do the math -- that the total stored energy has decreased.
Hope that makes sense -- I did skip some details, such as doing the math explicitly, not knowing how much calculus you have covered in school yet. If you have covered volume integrals in a multi-variable calc course, we could get more into those details if you like.
Likes JimBeans
Thanks for the replies. I think the fault in my reasoning may have been that I only considered the effect of one charge on the other.
I have done multi-variable calculus, if you have time i'd like to see the details.
Thanks again.
I can provide some clarification on this concept of work done by the electric field.
Firstly, it is important to understand that electric fields do not have energy in the traditional sense. They are a force that is exerted on charged particles, and this force can cause work to be done on those particles. The energy in an electric field comes from the charges that create the field, not the field itself.
When the electric field does work on another charge, it is transferring energy from the source charge to the charged particle. This does not necessarily mean that the source charge is losing charge itself. The electric field can do work on a charged particle without changing the charge of the source.
Think of it this way: when you push a book across a table, you are doing work on the book and transferring energy to it. This does not mean that you are losing mass or energy yourself. Similarly, the electric field is doing work on the charged particle without losing energy or charge itself.
I hope this explanation helps to clarify any confusion. It is important to remember that energy and charge are two separate concepts in the context of electric fields.
FAQ: Work done by the electric field
What is work done by the electric field?
The work done by the electric field is a measure of the energy transferred when a charged particle is moved between two points in an electric field. It is equal to the force applied on the particle multiplied by the distance it is moved.
How is work done by the electric field calculated?
The work done by the electric field can be calculated using the formula W = F * d, where W is the work done, F is the force applied, and d is the distance the charged particle is moved.
What is the unit of work done by the electric field?
The unit of work done by the electric field is joules (J). This is the same unit as for work and energy, as it represents the amount of energy transferred.
Can work done by the electric field be positive or negative?
Yes, work done by the electric field can be positive or negative. If the force applied and the displacement are in the same direction, the work is positive. If they are in opposite directions, the work is negative.
What is the significance of work done by the electric field?
The work done by the electric field is important because it is a measure of the energy transfer in an electric field. This energy can be harnessed to do work, such as powering electrical devices. It is also a key concept in understanding the behavior of charged particles in electric fields.
