Work done during quasi-static, isothermal expansion from P_i to P_f
The discussion revolves around the calculation of work done during a quasi-static, isothermal expansion from initial pressure P_i to final pressure P_f. The original calculation used the integral of pressure with respect to volume, leading to a work expression of W=nRT ln(P_f/P_i). However, the calculated value of -7294 J differs significantly from the book's answer of -3.17 x 10^3 J, prompting a review of the conversion of temperature to Kelvin. A participant points out a typo in the equation for volume, clarifying that the correct equation should be V=nRT/P, not V=-nRT/P. The conversation emphasizes the importance of careful unit conversion and correct application of the ideal gas law.
zenterix
(a) Show that the work done by an ideal gas during the quasi-static, isothermal expansion from an initial pressure ##P_i## to a final pressure ##P_f## is given by
$$W=nRT\ln\frac{P_f}{P_i}$$
(b) Calculate the work done when the pressure of 1 mol of an ideal gas is decreased quasi-statically from 20 to 1 atm, the temperature remaining constant at ##20^{\circ} C## (##R=8.31 J/mol\cdot deg##).
##W=-\int_{V_i}^{V_f} PdV##
I am posting this question after I thought I had easily solved the problem, but then when I checked the back of the book I saw that I was incorrect.
Here is what I did.
(a)
$$W=-\int_{V_i}^{V_f} PdV\tag{1}$$
$$V=V(P,T)-\frac{nRT}{P}\tag{2}$$
$$dV=\left ( \frac{\partial V}{\partial P}\right )_T dP+\left ( \frac{\partial V}{\partial T} \right )_P dT\tag{3}$$
$$=\frac{-nRT}{P^2}dP\tag{4}$$
Now we plug (4) into (1)
$$W=\int_{P_i}^{P_f} \frac{nRT}{P}dP=nRT\ln{\frac{P_f}{P_i}}\tag{5}$$
(b)
At this point I simply plugged the values into (5)
$$W=1\text{mol}\cdot 8.31 \mathrm{\frac{J}{mol ^\circ C}}\cdot 20^{\circ} \text{C}\cdot \ln{\frac{1\text{atm}}{20\text{atm}}}\tag{6}$$
$$=-7294\text{J}\tag{7}$$
The book answer says ##-3.17\times 10^3## J.
zenterix said:
(b)
Be careful: indicate that you converted the 20 °C to kelvin. Otherwise, I get the same answer as you.
Where did you get Eqn. 2 from?
Incidentally, you could have done the initial derivation differently by using the product rule for differentiation: $$PdV=d(PV)-VdP$$At constant temperature, d(PV)=nRdT=0, so, at constant temperature, $$PdV=-VdP=-\frac{nRT}{P}dp$$
Likes zenterix and MatinSAR
Indeed, I did use Kelvin.
Equation 2 comes from the equation of state for ideal gases. I think you may be asking because of the typo I have in that equation.
It should be
$$V=V(P,T)=\frac{nRT}{P}$$
I accidentally had a minus sign in place of the second equals sign.
Likes Chestermiller
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
